2.8 wont start?!
Old Feb 25, 2007 | 12:51 PM
lilbanger's Avatar
Car: 91 firebird
Engine: 3.1L
Transmission: AT
2.8 wont start?!
I have recently purchased this car it is a 88 camaro with a 2.8L/ 5-spd, when I bought the car the guy said it needed a battery(reason it wasnt running)so I thought! I have got it home and put in a battery, changed plugs, wires, coil, air filter, and I still cant get it to run. It will turn over and try to run and sometimes it will run, if I pat the gas over and over, but it still doesnt run like it should, like it is out of time or something. I have checked the timing and and everything is in time. Just wondering if any of you have had this problem?
Old Feb 25, 2007 | 12:54 PM
firstfirebird's Avatar
Are you getting spark?
EDIT: Bright blue to be exact.
Old Feb 25, 2007 | 01:14 PM
lilbanger's Avatar
Car: 91 firebird
Engine: 3.1L
Transmission: AT
yes.. getting plenty of spark.....and its blue. like I said, it will crank but it will not stay running, and when it cranks, it runs like it is out of time or something. when I push the pedal it dies, but if I pat the pedal it will barely stay running.
Old Feb 25, 2007 | 02:08 PM
Is the vacuum advance hooked up?
Old Feb 25, 2007 | 02:34 PM
lilbanger's Avatar
Car: 91 firebird
Engine: 3.1L
Transmission: AT
I just rechecked all my vacuums and all loooked to be fine, could it be the injectors? forgot to mention it multiport fuel injection
Old Feb 25, 2007 | 03:27 PM
It could be anything from injectors to o2 sensor to MAP sensor to ECM ....
The problem is trying to DAGNOSE the problem. Have you checked the ECM for codes? (Click on FAQ's and scroll to the bottom and find where it talks about a paper clip).
Old Feb 25, 2007 | 04:01 PM
lilbanger's Avatar
Car: 91 firebird
Engine: 3.1L
Transmission: AT
yeehaaawwwww!!! got it running! didnt do nothing but put the battery back in it, and cranked it up!! Must have had some bugs in it or something!! Still not running that great, but it is running!!
Old Feb 25, 2007 | 04:05 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
I tried that and nothing changed for me.
Old Feb 25, 2007 | 04:09 PM
lilbanger's Avatar
Car: 91 firebird
Engine: 3.1L
Transmission: AT
wanna buy mine?
Old Feb 25, 2007 | 04:15 PM
Old Feb 25, 2007 | 04:16 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
No thanks. The money spent buying yours could fix mine. Besides my car looks better.
Old Feb 25, 2007 | 04:20 PM
lilbanger's Avatar
Car: 91 firebird
Engine: 3.1L
Transmission: AT
I agree...100%!!
I just bought mine... give me about 2 months, if I still got it!!
Old Feb 25, 2007 | 04:47 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
My car is up and running again. My TB gasket was sitting on top of the lower bolt. The bolt missed the hole. I can't believe that that was the whole problem.
Old Feb 25, 2007 | 05:02 PM
lilbanger's Avatar
Car: 91 firebird
Engine: 3.1L
Transmission: AT
yeeeeeehhhhaaaaaaaawwwwwwwww!!!!!!!!!!!!!
Glad you figured it out!!!!!!!!!!!!
Cleotiz
Jan 6, 2018 08:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
E Rod
Aug 28, 2015 05:17 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
86Base
Aug 8, 2015 01:34 PM
