motor Swap
Old Feb 27, 2007 | 01:06 PM
pletch's Avatar
Car: 86Camaro RS
Engine: 2.8L V6
motor Swap
I searched the threads and didnt find any revalent to my situatuion, so please help me out.
I have decided to swap my motor from a 2.8 to a 3.4 except when i called the yard to get a 3.4 that would line up to a rwd they wanted a 1100. They didnt know what motors i could use to swap though. So I am asking you what can i use for this motor swap?
Old Feb 27, 2007 | 02:01 PM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
More searching is required. Unless you want a real project on your hands, get a 3.1 or 3.4 out of a camaro. A 3.1 may be cheaper due to a longer production run. Any FWD block will require new pistons/rods, heads, and the starter bolts redrilled. Check out my sig to see what I did to make a 2.8 block into a 3.1.
Old Feb 27, 2007 | 07:47 PM
pletch's Avatar
Car: 86Camaro RS
Engine: 2.8L V6
Yeah thanks, now i feel like a fool! I did do some more searching and found valuable info here. i would still appreciate some more comments though.
Old Feb 27, 2007 | 08:37 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
I applaud your efforts to get to the largest displacement direct swapping option. I can tell you, though, that you should not look past the later 2.8 or 3.1 V6 engines either if you are using it as a daily driver.
Just make sure to get one from 1987 or newer. You can use S-truck 2.8 throught 1990 or Camaro and Firebird through 1995 2.8 / 3.1 / 3.4
Have fun!!
Old Feb 28, 2007 | 11:43 AM
pletch's Avatar
Car: 86Camaro RS
Engine: 2.8L V6
searching
i have been doing alot of searching and im starting to find out that a might be a better choise for the availbity of option. How do you feel about that?
I have been doing a lot of searching and im starting to find out that a 3.1 might be a better chose for the amount of options available . How do you feel about this?
Old Feb 28, 2007 | 04:06 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
I had a 90 firebird with a 3.1 and it was MUCH stronger feeling than the older 2.8's...
You will be happy with a 3.1 if you use it; it will NOT make your car into some kind of road rocket... it will be better, though...
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
E Rod
Aug 28, 2015 05:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
