some problems
Old Mar 7, 2007 | 12:17 PM
87CamaroDude's Avatar
Car: 1987 Camaro LT
Engine: V6 2.8 (173)
Transmission: 5spd
some problems
I have a coolent leaking somewhere around the waterpump and when its warm it will stop. My dad thinks there could be a screw that needs to be tightend.
The engine light it on and the diagnostics say MASS AIR FLOW but I replaced that and 4 days later with lots of driving the light is still on. Someone said I have a exhaust leak, could that be the problem bringing up false diagnostics?
Old Mar 7, 2007 | 08:11 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
problem 1
look at your water pump seal. it is probably just starting to go bad if it warms up and stops. There is a "weep hole" on the bottom THAT IS SUPPOSED TO LEAK exactly as you describe to tell you that it is time for a change BEFORE the car leaves you stranded. Unfortunately it seldom works properly. You must be the lucky guy...
Problem 2
Are you running a K&N filter? Sometimes the oil from the filter puts a slight film on the MAF that throws a code and then goes away after a time...
Old Mar 7, 2007 | 11:43 PM
Car: 1987 Camaro LT
Transmission: 5spd
problem 1
Should I get that done right a way? How would I fix it
Problem two
I only have some stock air filters, I havn't yet bought the air filter I want
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
