Smog Pump
Old Mar 11, 2007 | 01:15 PM
88ta327's Avatar
Smog Pump
How Do I take off My Smog Pump. I have an 88 firebird with a 2.8 v6.
Old Mar 11, 2007 | 01:36 PM
firstfirebird's Avatar
Is there a reason?
Pull the belt, unbolt the smog pump and EGR valve.
Make a cover for the intake manifold where the exhaust gas goes in.
Make a cover for the hole left in the exhaust manifold.
Measure for your new belt and install.
Old Mar 11, 2007 | 01:51 PM
daves12secV6's Avatar
Originally Posted by firstfirebird
Is there a reason?
im not sure but if u dont install the idler pulley were the smog pump used to be i dont think the belt will have enough contact on the water pump.causing the water pump to slip.
though u could try it,if it dosent work without the idler pulley u can get one from the junkyard off any 2.8 powered firebird or camaro
anyways why do u want to take the smog pump off? is it seized up, or do u just think the car will run better without it ???
without the smog pump the cat converter will not work as efficiantly raising the cars emmisions
Last edited by daves12secV6; Mar 11, 2007 at 01:53 PM. Reason: Automerged Doublepost
Old Mar 11, 2007 | 02:12 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
I dont think you would have to do anything with your EGR when you take out your smog pump.
Old Mar 11, 2007 | 02:31 PM
No you will have to change the routing, here's a pic...
You are correct, but if you are getting rid of the pump why would you want to keep the EGR?
italiano67
Dec 11, 2016 09:21 AM
J.C. Denton
Aug 31, 2015 03:11 AM
Victor6
Aug 30, 2015 02:09 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
mustangman65_79
Aug 7, 2015 09:55 PM
