needing to do a intake manifold once and for all
Old Mar 12, 2007 | 03:37 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
man so many things have been keeping me from doing this darn intake manifold gasket on my 91 3.1, camaro, but i think next weekend im start it, hopefully ill be able to dothis in a day, but its leaking bad now.,,. i went out to del taco last nits and the oil smoking off the ex pipe was extreamly imbarrasing,
I think another thing that keeps me from doing it is somthing i remember someone here saying about the dizzy,. it needs to come out or sumthing,, and thats the point i dout myself dont wanna fug it up,,
so perhaps im just wanting to hear some positive feedback to get me motivated to do it,,,,,,,,,,lol
Old Mar 12, 2007 | 02:11 PM
mvftw's Avatar
Besides getting the intake gasket set. Plan on replacing the O-rings for the injectors...maybe tough to find, but after you button it all together and the injectors leak...
Old Mar 12, 2007 | 03:16 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I assume oil is leaking onto the manifolds? If so, thats possibly your valve covers, and the part of the intake that requires removing the dizzy doesnt need to be messed with.
Now if your leaking from around the valley of the intake, then yes your dizzy needs to come out.
Now you may be leaking from around the dizzy(commen leak).
Injector orings as mvf said will need to be replaced and doesnt come in the kit. If they dont list them for your car, ask for injector orings for a same year TPI v8 camaro, or a 5.0 ford SFI engine. All same injector design there.
If you have to pull the dizzy, the kit does not come with either of the dizzy gaskets, and them need replaced too. These are the same as a SBC dizzy.
Old Mar 13, 2007 | 03:31 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
pulling the dizzy is cake. just take a photo of it before you remove it, so you know exactly which way it is pointing. when you put it back in make sure thats the way it points.
Old Mar 13, 2007 | 08:16 AM
pairtoe's Avatar
yeah just mark on the base wich way the rotor is pointing and put it back in that way its real easy
Old Mar 13, 2007 | 10:15 AM
Dale's Avatar
Engine: 350 S-TPI
Gotta mark 2 places. Rotor button to base, base to hold-down clamp.
86IROC112
Aug 17, 2015 02:00 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
st.evel07
Aug 13, 2015 06:15 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
Jake_92RS
Aug 11, 2015 10:39 AM
