starting problems 2.8l camaro
Old Mar 15, 2007 | 06:37 PM
jukna's Avatar
Car: 88 camaro
Engine: 2.8L
Transmission: AT
my problem started after i replaced the fuel pump , it takes a good 40 to 60 seconds to start sometimes longer cant hear the pump running when i crank but pump runs when i jump it, i also replaced the relay and relay harness thinking that was the problem and checked the fuse, no luck. i know the oil pressure switch energizes the pump if the relay or anything else does not work so the car runs. once it starts it runs fine, idles perfect, no hesitation just cant figure this one out
Old Mar 16, 2007 | 10:40 AM
tnt_viper's Avatar
Car: 89 Camaro RS, 99 Sunfire GT
Engine: 2.8L, 2.4L
was it a new pump or a rebuild pump? because it could be a deffective pump
Old Mar 16, 2007 | 11:09 AM
jukna's Avatar
Car: 88 camaro
Engine: 2.8L
Transmission: AT
brand new bosch pump,the only thing that makes me think its not the pump is that when i jump it, it runs and once the car starts in runs fine
Old Mar 16, 2007 | 11:59 AM
tnt_viper's Avatar
Engine: 2.8L, 2.4L
is the connectors corroded or damaged? and the same for the wires?
does the car have problems starting all the time? or just whyen it's hot? because it could also be the fuel pressure regulator.
Old Mar 16, 2007 | 04:31 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
You need to check for the power coming IN to the relay. I believe the computer tells the relay to prime up before it gets the oil pressure signal.
Why did you replace the pump? Did you have this problem with the old pump? You may just have a bad connection in the wire going between the computer and the relay...
Check all wiring connections to the relay and then try them again.
You jump the relay and it works? Jump it how? Are you just jumping the main wires that "power up" the pump? Try jumping the wire that turns the relay on from the computer. Your Chilton's or Hayne's manual should tell you which wire...
My Firebird manual says that the dark green wire with the white stripe should power up the relay for priming...
Old Mar 16, 2007 | 04:50 PM
jukna's Avatar
Car: 88 camaro
Engine: 2.8L
Transmission: AT
the pump was bad, and yes i was jumping just the pump i didnt even think to jump it through the relay the haynes does have a wiring diagram il check it all out tomorrow we are getting hit with a sleet storm up here and i have no garage
Old Mar 16, 2007 | 04:55 PM
jukna's Avatar
Car: 88 camaro
Engine: 2.8L
Transmission: AT
oh also the old pump did not have this problem it started after i installed the new pump but i was also messing around with the relay thinking it might have been that when the old pump went maybe i messed something up?
Old Mar 16, 2007 | 04:57 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
This is the PERFECT time to go through hours and hours of old posts!!!
After years of working on these cars, I think the wiring diagram in the Chilton Total Car Care manual is the best. It's the easiest for me to use, anyway. It is well worth the money.
92camaroJoe
Jul 29, 2023 07:57 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
