a quick oil pump question
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Ok guys heres a real quick question. Do you need to use any RTV sealer on the oil pan gasket? I'm getting some conflict from the book and the instructions from the gasket. The book says to use some, but the gasket says not to. I noticed that there were some traces of sealant at the front and back of the engine from the factory (timing cover and back area).
So basically, do you have to use sealant anywhere on the oil pan gasket? Thank you in advance!
BTW, the gasket I am using is from felpro.
oops, just noticed I put oil pump rather than oil pan! lol
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: a quick oil pump question
The one piece molded rubber gasket does not need any thing. I used to put just a few spots of weather strip adhesive just to help hold it in place but not required.
Engine: 3.4 / 5.0
Excellent! Exactly the answer I was looking for! Thank you very much!
Engine: 3.4 / 5.0
hmm, i was actually thinking of doing that. I don't see how it woudl really hurt the gasket anyway. Did you put it anywhere else or just in these little areas? I'm kinda wondering if there should be any at the bottom of the timing cover.
Car: 1998 Camaro Z28
Engine: 6.0L
also put a lil bit where the front cover meets the block so you dont get any leaks between that sealing area.
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
