Vacuum question
Old Apr 4, 2007 | 06:13 PM
ron91rs's Avatar
Car: 91 rs
Engine: 3.1 v6
Vacuum question
Can i use a vacuum guage to prove i have no vacuum leaks.
I have searched and have found no exact steps.
Any help greatly appreciated !!!
Old Apr 4, 2007 | 11:11 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: Vacuum question
technically yes, but it's not very acurrate.
You should have about 18" of vacuum with an idle at about 750 RPM. if both are true, then I would assume no vacuum leaks.
The best way to tell though is to spray carb cleaner everywhere that might leak, if the idle goes up, then you have one.
Old Apr 4, 2007 | 11:40 PM
tnt_viper's Avatar
Car: 89 Camaro RS, 99 Sunfire GT
Engine: 2.8L, 2.4L
Re: Vacuum question
passing over the lines with a propane bottle works too, if theres a leak, the propane will make the RPMs go up
Bubbajones_ya
Aug 28, 2015 02:17 AM
mdtoren
Aug 23, 2015 12:52 PM
redmaroz
Aug 16, 2015 11:40 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
