Oh yea I brokded it
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
Oh yea I brokded it
yea so long story short, i had a whine in my rear end., that was throttle sensitive,. and i replaced it with a whole nother rear end., nothing new.,just one from a doner car., and every thing was going good,. and as i was driving it down to the auto zone for fluied,. it sounded like somthing mechanicaly went wrong like clanking and then like something dragging,. then started go go away., now it seems it right back where i started from it has a whine to it at hiway speeds then goes away when i let up off the throttle.,,.what is my problem ., could it be possible (and hear me out on this) that the chity shocks that are on there is causeing it to mess up,. someone putting to much pressure on the pinion., from bottoming out,. cause im sitting really low,. i was gonna replace the shocks but seemed i could not turn the fuggin nut loose with out the stud turnin as well,. anyway when i got home i put in a whole bottol of fluied., i could not believe it took the whole, i thought for sure, there was some fluied in there.,,. so what yall think ,.,. where did i do damage., or is this happining from my shocks??
Thanks in advance
Thanks in advance
Re: Oh yea I brokded it
if there was no gear oil in the rear its burnt up now,a 7.5 inch rear takes about 2 quarts of gear oil.
if u ran it without any it will have most deff burnt up the bearings and the gearset depending on how far/fast u were driving
and btw u didnt hurt the rear with blown out shocks
is ur sig big enough??? i had to scroll down a page anda half almost just to reply lol
Yeah your exsactly right Bro!., dang it,. now ami bout retarded or wht? lol,. crap if i dont deserve the idiot of the year award.,oh man!
Yeah see i dude i got it from said there was fluid in there., but could use a lil more,. i figured ok no problem., ill get fuel and take her to vato zone! well i made it but on way home somthing went wrong., made loud mecanical noise like somthing falling apart, then like something dragging,. i though it was the ebreak cable i have tied up out the way for now,. but nope i used zip ties.,lol
Any way i had to inch it home and the sound slowly went away the cooler it got,. got home put in only one quart of lube,. and it took it all,. then i drove around,.,. now the good thing is that its quieter then the last one that had this problem.,but bad thing is that it to does the same thing,..,
ERRR im so pissed at myself @$^@#@#
Car: 1998 Mustang
Engine: 3.8L V6
Transmission: Automatic with overdrive
Axle/Gears: 2.73:1 axle ratio
and did not mess up anything. Last edited by 83camaroMN; Apr 6, 2007 at 09:38 AM.
