1/4 mile times
Old Apr 5, 2007 | 10:36 AM
pairtoe's Avatar
1/4 mile times
hey need some opinions on what you guys think i will run in the 1/4 mile on my cars new setup.
car is a 1987 2.8l MPFI, with non posi and stock gears.
later in the summer a posi rear end i got off an 88 z28, and some 3.73 gears will be going in.
engine:
-heads ported/polished
-high performance spring/locks/retainers.
-intake mild port/polish job
-delta cam (specs in vb garage)
-1.6 ratio roller rockers
- comp cams high energy push rods
- 19lbs fuel injectors
- 125 wet shot nitrous
-headers and 2-1/4 true dual exhuast with dynomax bullets
i am finally now in the proccess of putting back together, shoudl be done by next week sometime. also my brother got a new video camera so i will post of a vid as soon as i get one. just wanted to see what you guys thougt my times might be.
Old Apr 5, 2007 | 12:32 PM
boostedv6's Avatar
Re: 1/4 mile times
high 15's?
Old Apr 5, 2007 | 12:35 PM
noahTHEpurdy's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
Re: 1/4 mile times
Originally Posted by boostedv6
high 15's?
Yep, mid, to high 15's sound about right.
Old Apr 5, 2007 | 07:13 PM
firstfirebird's Avatar
Re: 1/4 mile times
I agree with the 15's, but who knows until you get there . Dave thinks I will get in the low 14's with the turbo, but I am not expecting that good of results.
Old Apr 5, 2007 | 07:40 PM
daves12secV6's Avatar
Re: 1/4 mile times
both of u should go into the 14's 125shot is pretty big all in its own,but ur also adding in the ported heads,cam and ex.
actually i shouldnt say 14's it really does depend on when u start to spray the nitrous, if u spray that thing out of the hole u shoudl go faster then firstfirebird,but if u dont spray till further down track it will slow the car up a bit,hoep u got some really good tires and a posi
Old Apr 6, 2007 | 07:38 AM
pairtoe's Avatar
Re: 1/4 mile times
yeah i am thingking of getting a set of mickey thompson ET street radial tires, and i have a posi rear i just never put on yet.
but with the nitrous i have a WOT switch, but i might get a window swith but dunno yet, and i will spray the whole way down the track.
Old Apr 6, 2007 | 10:12 AM
DaSkinnyGuy's Avatar
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
Re: 1/4 mile times
I say 14.6
Old Apr 6, 2007 | 01:16 PM
HPE's Avatar
HPE
Re: 1/4 mile times
You can not succesfully go true duals on such a small displacement motor and the long exhaust routing we have. There have been several people that have tried this over the years on this board and every one of them experienced the same result.What happens is only 3 banks of a 3l motor is just not sufficiant to keep the exhaust gasses hot all the way back to the tailpipe. you are pushing 1.5L of engine bank and it is cooling and getting flow restrictions. Keep 6 into one.
Also, there is no mention or asking from anyone if this car is a stick or auto? How can you make a prediction not knowing this key info as to what drivetrain and its condition. A stock slush box isn't going to get you any higher than mid to high 15's on that build combo.
Then the question of reliabiliuty comes in real quick- you may be lucky to get one run in.
Old Apr 6, 2007 | 06:53 PM
pairtoe's Avatar
Re: 1/4 mile times
true about the exhaust, but it sounds real mean and i like it allot and would sacrifice performance for the good sound.
its an automatic and i forgot i have a transgo shift kit, but its not installed yet but will be before it goes on the road.
and like i said right now rear end is stock now with the stock gears, but i have a 88 z28 posi rear going in it this summer with 3.73 gears.
Old Apr 6, 2007 | 09:47 PM
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
Re: 1/4 mile times
LOL you have a shift kit but its not in the car. I love that its like what a ***** would tell you as an excuse why they lost. Thats like saying you have a procharger but all you have is the sticker on the car.
Old Apr 7, 2007 | 08:03 AM
pairtoe's Avatar
Re: 1/4 mile times
yeah i bought it, but i haven't installed it yet. but like i said before it will be in the car before i take it out. i originally had a b&m shift kit, but was talked into returning it to buy a better one, thats why its not installed yet.
Old Jun 21, 2007 | 10:27 PM
91_rs-teal's Avatar
Car: 1991 Camaro, Best 12.40 @ 115.8 MPH
Engine: LS1, HCI, Headers
Transmission: T56, Monster Stg. 4
Axle/Gears: 7.5" 10 Bolt - 3.73's w/ posi
Re: 1/4 mile times
so what did ya get???
i got 17.03 with cat,smog and a/c delete and a shift kit
Old Jun 22, 2007 | 12:35 PM
pairtoe's Avatar
Re: 1/4 mile times
a spun bearing... well im expecting the worst at this point. but it broke down after i had it tunned and running really good. as for the nitrous i never used it but i will tell you that it was a ton faster with them heads and cam then it was stock. i bet i could have ran a high 15 with a better rear and shift kit.
Old Jun 22, 2007 | 09:47 PM
Engine: 3.1
Re: 1/4 mile times
The 3.1 heads same as the 2.8 heads?
Old Jun 22, 2007 | 09:56 PM
Re: 1/4 mile times
YEP, just the 2.8 has flat pistons and the 3.1 has a 12cc dish . (ohy yeah, the 3.4 heads are identical also, hence the 1st gen 60*).
Old Jun 22, 2007 | 10:34 PM
pairtoe's Avatar
Re: 1/4 mile times
hmm i always thought the pistons were the same in both engines. learn somthing new everyday.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
evilstuie
Jan 9, 2020 08:29 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
