v6 swap
Old Apr 6, 2007 | 07:51 AM
87CamaroDude's Avatar
Car: 1987 Camaro LT
Engine: V6 2.8 (173)
Transmission: 5spd
v6 swap
I want to swap a bigger more powerfull v6 into my Camaro. I'm not sure what kind of chevy engines there are that will fit with my car and so I can keep the old 5 sp tranny. I was thinking a 3.8 so I can turbo it and get some good power out of my car. What kind of F.I. engines of that time were the best that I would be able to use?
Old Apr 6, 2007 | 08:54 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: v6 swap
If you do a search you'll find 3.4 from the 4th gen F-body will be your best bet.
Old Apr 6, 2007 | 09:42 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: v6 swap
The 3.4 is basically a direct swap. It would be the easiest to swap into youe car.
Old Apr 6, 2007 | 09:49 AM
Car: 1987 Camaro LT
Transmission: 5spd
Re: v6 swap
Do all the brackets stay the same? I think it might be a good idea to find a rebuild.
Old Apr 6, 2007 | 10:07 AM
Re: v6 swap
Yes.
Old Apr 24, 2007 | 12:53 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
Axle/Gears: limited slip posi 3.42
Re: v6 swap
go to the tech articles and look for ked85's 3.4 swap boogie
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
