Tightening the distributor down
Old Apr 10, 2007 | 02:55 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
My distributor keeps vibrating itself out of place... I adjusted it by turning it ever so slightly until I had it running absolutely perfect. 500-600 miles later, and it's terrible again. I assume there's supposed to be a bolt somewhere to tighten it down, but I can't see anything down there. Any help?
Old Apr 10, 2007 | 03:13 PM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
Re: Tightening the distributor down
There should be a 15mm (?) bolt almost underneath the black EGR tube that crosses behind the intake. This bolt tightens a plate that holds the base of the distributor down. Make sure its tight. You'll need to take the connectors out of the distributor ICM, and you'll need a 15mm socket, a swivel, and an 8" extension.
Old Apr 10, 2007 | 03:14 PM
forkvoid's Avatar
So it's straight down from the general area of that vacuum line that connects into the rear of the intake?
Old Apr 10, 2007 | 03:40 PM
Blue1989RS's Avatar
Car: 1989 RS
yes.
Its under the passenger side of the dizzy, almost dead inbetween the two Ignition Control Module plugs. Be very careful not to destroy the IGM as you tighten this bolt!
Old Apr 10, 2007 | 10:47 PM
JohnSjr's Avatar
a 15mm crowsfoot works nicely as well.
bolts on the passenger side of car ( almost directly under module/wire assembly )
Old Apr 11, 2007 | 08:43 AM
mvftw's Avatar
This is what you need... plus an extension...
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
gord327
Oct 3, 2015 01:25 PM
FormulaEngland
Sep 30, 2015 01:50 PM
Damon
Sep 26, 2015 04:29 PM
