Vacuum hose leak??
Old Apr 25, 2007 | 08:45 PM
83' maro's Avatar
Car: 1987 IROC-Z Camaro
Engine: LB9 305, edelbrock intake.
Axle/Gears: 10 bolt, 3.73 posi w/ disc brakes
Vacuum hose leak??
Hey guys/girls, I'm pretty new here. I just got myself an 83 2.8 V6 Camaro about 2 weeks ago. I was wondering after a few minutes of running maybe about 5 the idle dips and comes up from 1500-500 every 1-2 seconds. Now when I step on the gas pretty well the car sputters and sometimes just shuts right off. My father and I both think it's a vacuum leak? I just wanted everyones expert opinions
Old Apr 25, 2007 | 11:53 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: Vacuum hose leak??
It sounds like a vacuum leak problem, but the carb'd cars were less likely to idle up and down that much than the EFI cars. Sounds like it's time to break out the carb cleaner and spray all the vacuum areas to see what you can find. Don't forget to spray around the brake booster.
86IROC112
Nov 27, 2015 09:54 AM
85 Jimmy
Sep 30, 2015 07:56 AM
Stryker412
Sep 20, 2015 06:59 PM
84redta
Sep 19, 2015 09:58 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
