car wont start and making gulp gulp sound!!
Old May 1, 2007 | 08:41 AM
camaro2.8173's Avatar
ok i just bought an 87 camaro 2.8 with a blown head gasket. and i just finished chaging it, put it all back together and filled it all back up and it wont start. its got new every thing plugs, wires, cap rotot, distributor. i have a fuel pressure gauge on it and im getting about 35-40psi. it will crank and crank but notihng happens, then it begines to smoke real bad at the throttle body adn smells like somthing is burning. then once the key gets turned back it will make a popping noice for a couple seconds. oh and when its cranking over i can hear a sound like gulp, gulp gulp, but i dont know what that could be, is it the oil pan, its got fresh oil in it. thnaks for the help.
Old May 3, 2007 | 05:35 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: car wont start and making gulp gulp sound!!
Try twisting the dizzy in one direction or the other. It sounds as though your timing is WAAY off. You may even have to march the plug wires around on the cap until you find the right position.
Also, another possibility is that you overtightened the rocker arm nuts, and a few valves are hanging open full time. Before you do anything, do a compression test on all six cylinders. I don't remember what the 2.8's cylinder PSI is supposed to be as it is going on three years since I had my 2.8, but you should probably be shooting for around 140-150, IIRC. If anyone knows for sure, feel free to correct me. Anything lower, and either your rocker nuts are too tight or too loose. Proper assembly (clean the pushrods first or you're never going to get it right) is to remove all play in the valvetrain and tighten the nut an extra quarter turn.
Old May 3, 2007 | 09:42 PM
XxSgtReillyxX89's Avatar
Car: 91 Trans Bird
Engine: 3.1 MFI
Axle/Gears: Stock
Try the distrib first like Mav said but then check your injectors make sure u got 12.0 omhs anything lower replace it
Old May 3, 2007 | 10:10 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Well my problem was that I didn't know there was 3 marks on the balancer, and I timed to the wrong mark. My car did EXACTLY what you described, so definitally check the timing.
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
mizz0313
Aug 12, 2015 06:45 AM
killer777
Aug 8, 2015 02:47 PM
mustangman65_79
Aug 8, 2015 12:07 PM
