Varajet Carb Question, Did I mess Up?
Old May 2, 2007 | 10:30 PM
locomoshun's Avatar
I'm changing all the EFI/Computer stuff on a 91 3.1 to carb and old style distributor. I bought a distributor and coil from a 82 S-10 at the pick-a-part. No problem there. I got a Varajet and matching Edelbrock top from a guy that converted to a Holley 390. I have an Edelbrock intake lower on the way from Summit. My plan it to use the Varajet until I can afford to go with a Holley.
I'm a little concerned that I may have a computer controlled carb. Its from a 85 S-10, and it has a couple of wires and a plug coming from the base. Is this a preheat wire or did I buy too late a model carb?
Old May 2, 2007 | 10:52 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: Varajet Carb Question, Did I mess Up?
why in the world are you going to old tech? Just curious as to the reasoning.
Anything in the mid to late 80's is computer controlled I think. Is there a connector at the top?
Old May 3, 2007 | 06:46 AM
locomoshun's Avatar
I'm swapping the engine into a 1972 MGB. I doesn't get any older tech than that.
Old May 3, 2007 | 10:51 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
ahhh...I knew there had to be a reason.
Old May 4, 2007 | 06:30 AM
locomoshun's Avatar
So what about it anyone? What years are the non computer carbs?
Old May 5, 2007 | 08:03 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
before 1981
MustangBeater20
Oct 29, 2022 09:20 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
theurge
Aug 21, 2015 12:46 PM
PestilenceIV
Aug 20, 2015 03:32 PM
redmaroz
Aug 16, 2015 11:40 PM
