Revving by motor on startup
Old May 5, 2007 | 07:34 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
On start up my motor has revved by itself a few times. It will rev to 3-4K then back down to 1K and do it a couple more times and stop doing it. Is this the IAC opening and closing on its own, or I have been told that it could be the crank sensor (where is that located)? Any info will help thanks.
Old May 6, 2007 | 12:22 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: Revving by motor on startup
well...seeing as that you don't actually have a crank sensor, I don't think it's that. You most likely problem is the IAC. It gets clogged with crap and the motor itself gets gummed up. You can try taking it apart, but I just replace them, it's like $30. Just a personal opinion to replace it rather than bandaid it. You'll never get all the crap out of it.
Old May 6, 2007 | 08:41 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
The IAC is pretty new and all of the airways in the TB have been cleaned out and I checked all of it this past weekend. It does this once in a blue moon and hasn't done it in a while.
Old May 6, 2007 | 08:55 AM
firstfirebird's Avatar
Seems like you have some issue going on. You have had these kind of problems at idle for a while now? Are you getting any codes this time?
Old May 6, 2007 | 10:53 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
My idle is a little better but not much after everything that I have changed. IAC, TPS, MAF, EGR, plugs, wires, O2 snesor, and various vaccum tubes. I only get the occassional EGR code. The SES only comes on for a few seconds every once in a while. My idle now is ~1100-~1200. At ~1200 RPM the whol car vibrates and won't go much lower than that without being irratic and dying. I won't mess with it much more because I plan on rebuilding another motor with some goodies and stick it in there.
hydrolic144
Sep 8, 2015 06:55 PM
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
BurlyChev
Aug 22, 2015 11:42 AM
