What EXACTLY needs done to the Pacesetters to make them 3.1 smog compatable?
Old May 8, 2007 | 03:45 PM
noahTHEpurdy's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
I need to know exactly the issue with them and what exactly needs to be done so I can tell the shop I'm having do the work what they need to do. I know why they wont work with it, but not the exact reasons. Thanks in advance.
Old May 8, 2007 | 03:50 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
Re: What EXACTLY needs done to the Pacesetters to make them 3.1 smog compatable?
Well, speaking from a 2.8 view, the o2 sensor is further down on the pipe so you might have to extend the o2 cable down some.
Old May 8, 2007 | 09:05 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
egr should bolt up. look at your stock manifolds and see if there's and A.I.R. tubes going to them. If so, those will need to be plumbed into the headers, also. I don't know where you're located...if they check the carb number on the tag on the headers...they won't show up as legal on a 3.1. If they don't check that number, just plumb in anything that is currently plumbed into the exhaust and you'll be good.
Old May 8, 2007 | 10:54 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
You need pacesetter to put up the money to get the State of California to approve them. Until that point, they'll never be legal for the 3.1, BUT speaking as a tech, most guys are too lazy to check as long as the E.O. Number is visible.
Old May 9, 2007 | 09:49 AM
Engine: 3.1
No, just to pass the sniffer test. That's all I want. Plus, I don't want half of my A.I.R. system just dangling around in my engine bay. I'd like to keep it functional.
onefreakz
May 14, 2018 12:15 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
sreZ28
Aug 14, 2015 07:48 PM
guy76767
Aug 6, 2015 05:58 PM
