Help I can barely go up hills!
Old Jun 10, 2007 | 06:14 PM
Kryppy's Avatar
Car: 87 Camaro
Engine: V-6 MPFI 2.8 liter
Transmission: 700 R4
I have an 87 Camaro with the 2.8. I installed Pacesetter headers, threw away the cat., connected a Thrush glasspack directly to the end of the headers, gutted the bottom of the dual airbox & installed K&N filters. It sounds awesome. Runs great on flat roads but the slightest incline even on a highway while doing 70 she slows down drastically no matter how much I'm on the pedal. Too much flow? Not enough backpressure? This is what my friend told me. Another friend said it could be fixed by bumping up the fuel press. a few P.S.I.. Someone else told me a longer pipe with a "normal" muffler will solve it. I would like to try bumping up the fuel pressure a tad, how would I go about doing that? Thank you for taking the time to read my problem. Any input would be greatly appreciated. Thanks again.
Old Jun 10, 2007 | 07:01 PM
daves12secV6's Avatar
Re: Help I can barely go up hills!
yeah putting back on a reg full ex would help,ur losing a lil bit of tq without it.
but even still it shouldnt slow down that much going up a hill.
did u mess with the timming at all or change anything else? is the transmission downshifting like it should?
Old Jun 10, 2007 | 08:02 PM
Kryppy's Avatar
Car: 87 Camaro
(Thanx for the reply)-Yup timing is perfect & automatic tranny downshifting as it should.
Old Jun 10, 2007 | 08:11 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
I'm thinking that you have lost alot of torque. From what I understand you are just running headers with a glasspack on the end of both? You should put a full exhaust back onto the car.
Old Jun 10, 2007 | 09:39 PM
pairtoe's Avatar
you have the y-pipe though right? casue i did the same and put on the pacesetters with a dynomax bullet(just temp till i get it running good) but it still runs strong, when i didnt have the ypipe on, it was gut-less and backfired like crazy.
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Fanatic1074
Oct 2, 2015 03:47 PM
Hill1513
Sep 19, 2015 04:15 PM
ULTM8Z
Sep 16, 2015 09:15 AM
