89 rs help
Old Jun 12, 2007 | 12:39 PM
ncarrier's Avatar
Car: 1989 Camaro
Engine: 2.8 V6
89 rs help
i ran the trouble codes and came up with 34 which is the vacuum sensor circuit. does anyone know where to find the sensor? i have checked the wires going to the ecm and everything seems to be fine.
Old Jun 12, 2007 | 12:56 PM
pairtoe's Avatar
Re: 89 rs help
you can check your vaccum canister in the front of the eninge and make sure that the plugs going to them are nice and tight.
Old Jun 12, 2007 | 01:09 PM
daves12secV6's Avatar
Re: 89 rs help
34. Low voltage (high vacuum) at mass air flow sensor (or MAP sensor)
ur maf sensor is prolly bad
since ur car is an 89 u have a maf sensor not a map sensor,its the big plastic round thing in the air intake infront of the throttle body.
Old Jun 13, 2007 | 12:19 AM
ncarrier's Avatar
Car: 1989 Camaro
Engine: 2.8 V6
Re: 89 rs help
would that cause the idol to be up and down when you let off the gas while going down the road? if so i will get back to you about the maf sensor to let u know if it wrks.
Old Jun 13, 2007 | 08:33 AM
Re: 89 rs help
yes a bad maf can cause iratic idle.go get a new one but do not turn in ur old one as a core until u are sure the new one fixes the probloem.
reason being is if u turn in ur old one and the new one does not fix it,u cannot return it cause they wont give u back ur old on.
s
Old Jun 14, 2007 | 02:35 AM
ncarrier's Avatar
Car: 1989 Camaro
Engine: 2.8 V6
Re: 89 rs help
i will try that prob this weekend and i will let you know. thank you
Old Jun 27, 2007 | 09:45 PM
ncarrier's Avatar
Car: 1989 Camaro
Engine: 2.8 V6
Re: 89 rs help
i have a new problem. i have gone through 3 ignigtion moudles in the last prob 4 months. can someone tell me where the problem may lay? do i need a new distributar or some part of it? please let me know. as far as the other thing i haven't gotten to it yet, hopefully next weekend but first need to find out why i am going through so many of those things.
