Replacing the EGR valve...
Old Jun 28, 2007 | 11:28 AM
Bazookajoe254's Avatar
Car: 86 Firebird
Engine: 2.8 V6
I'm having some trouble with knowing which one to buy. If someone wouldn't mind going on AdvanceAutoParts.com and getting an idea of what I'm looking at...
http://www.partsamerica.com/ProductL...hFor=EGR+Valve
Some say they are for an automatic transmission only. I don't understand why that would make a difference in how the EGR valve works. Something to do with a constant vacuum maybe? Just my guess.
Which of those would be allright for me to buy and would fit my car? They all look like they have the same sized base.
Maybe I should just take off the old one and take it up to AdvanceAutoParts and just compare.
Old Jun 28, 2007 | 11:49 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: Replacing the EGR valve...
The best thin gto do is look at the old one, looking from the top you should be able to see the original P/N (you might have to clean it a little to see it better) then use that to get the right one for your car. I believe they physically the same outside but a little different in the internal porting. Not sure about that.
Old Jun 30, 2007 | 12:10 AM
Car: 86 Firebird
Engine: 2.8 V6
Thanks.
I still don't get why having an automatic would change how the EGR valve works. Oh well, guess it doesn't really matter.
mdtoren
Aug 23, 2015 12:52 PM
Out-Cast
Aug 17, 2015 10:57 AM
mdtoren
Aug 16, 2015 05:45 PM
drathaar907
Aug 6, 2015 04:20 PM
