right front clunk/poly bushing question
Old Jul 6, 2007 | 07:37 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
first off, i know its not the right place for this, but i seem to have a hard time getting any replies out of the suspension board......
after a search i couldnt find anything that related to my concern. under normal braking and occasionally when taking off again, i feel a clunk that is coming from the right front area. the ball joints have maybe 20k on them, strut bearings are maybe 30k. im thinking control arm bushings. i havent had a chance to get underneath it yet, but i was wondering if anyone has had this concern?
if it is the control arm bushings, and i put polyurethane ones in, how much does it affect the ride? ive already got Spohn control arms and panhard bar in the rear and it does seem stiff. im just wondering how much stiffer it will make it, not too bad, or night and day difference.
Old Jul 7, 2007 | 11:33 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: right front clunk/poly bushing question
I like the poly bushings because they last longer. I'm not sure that they stiffen it up so bad that you can't take it...
How many miles you got on your car? I'd look at the front sway bar end links. They seem to be the culprit on many other cars for what you're describing.
You can get those in poly too!!
Old Jul 7, 2007 | 03:51 PM
drdave88's Avatar
Engine: 6.0L
sway bar end links were replaced when i first got the car, so not quite 40k on them and theyre not broken either. the car has 162k on it.
Old Jul 7, 2007 | 06:29 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Have you checked them lately? sometimes the little self locking nut comes loose and allows those pieces to slap around...
also the main sway bar bushings contribute to that. the reason I brought it up is that you said it happens most often while braking or accelerating. The sway bar is very sensitive to those actions if anything is starting to loosen up...
Old Jul 8, 2007 | 08:06 AM
drdave88's Avatar
Engine: 6.0L
ill be under it in the next day or two to replace the oil pan, so ill have a chance to check it out then. also gonna finally put in those poly engine mounts i bought over a year ago, lol. ill see what i can find while im there.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
