IAC Adjustment ???
Old Jul 13, 2007 | 12:59 PM
mvftw's Avatar
IAC Adjustment ???
I want to adjust the IAC after reading this forum. Question is when it says to jumper A&B, can I use the ODBI code reader tool? I would say yes. I hate to use paper clips...
Old Jul 13, 2007 | 03:49 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: IAC Adjustment ???
You can use the ODDI reader fine, if you don't want to use a paper clip then a piece of wire works fine too.
Old Jul 13, 2007 | 08:36 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Originally Posted by mvftw
That thing is such a joke. I just bought the jumper key from AutoZone, does the same thing for $2. I use mine at my shop all the time.
But in answer to your question...yes, you should be able to use that.
The IAC automaticly adjusts itself every time you get above 40mph anyway. The only thing you use that for is setting the minimum air rate if someone's screwed with it.
Old Jul 13, 2007 | 08:55 PM
mvftw's Avatar
What I've read here is most people have a high idle surging problem. I have a low idle surging problem. This is the first time I read that the IAC self adjusts itself. I'm going to give it a shot tomorrow. I already cleaned it & the passage way.
Old Jul 18, 2007 | 01:13 AM
Bazookajoe254's Avatar
Car: 86 Firebird
Engine: 2.8 V6
Ever sine I started getting codes while driving I just keep a 5 inch long piece of wire in my arm rest compartment. Both ends are stripped and I have a piece of tape on it that has "A and B" written on it so I remember which ones (even though I never forget ). Advanced said their reader wouldn't read my codes. They tried it, nothing showed up. But I had one when I pulled into the parking lot...
Old Jul 18, 2007 | 06:18 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I always have a piece of wire too. Some of the guys who work at the parts stores are idiots. They must have had a OBDII reader. The first time I went there to pull comdes they had to dig around to find the OBDI reader.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
thejimsterz28
Sep 30, 2015 08:52 PM
