T5- need help plz!!!
Old Jul 17, 2007 | 12:16 AM
2tonedmaro89's Avatar
Car: '91 RS
Engine: 5.0L gross *** tbi
...when i like stop at a stopsign/ and go to put it back in 1st w/ the clutch all the way to floor/downshift, it makes this really strange noise....kindof like a bad bearing or something. almost wanna say like grinding but my buddy says its not the same sound. it only happens in 1st too
any suggestions?
Old Jul 17, 2007 | 01:10 AM
Car: '91 RS
Re: T5- need help plz!!!
To The Top!!
Old Jul 17, 2007 | 01:32 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
a test.
come to a stop at the stop sign, put tranny in reverse, then go to 1st. does it still grind? if so it may be your synchro(s).
this is about the extent of my transmission knowledge.
Old Jul 17, 2007 | 01:38 AM
Car: '91 RS
thanks man..any help helps lol. i'll try that 1st thing in the morning
Old Jul 17, 2007 | 01:51 PM
Car: '91 RS
it grinds going into rev. then and not 1st lol
Old Jul 17, 2007 | 01:55 PM
89N10GTA's Avatar
Car: 1989 GTA
Engine: 355 with Super Ram
Axle/Gears: 3.73 10 bolt with a True-trac
does it ever pop out of 1st when you are driving? and does it grind the whole time the clutch is in?
Old Jul 17, 2007 | 02:52 PM
Car: '91 RS
i think it has popped out 1ce or 2ce but ya as soon as i push the clutch in and go to put it in first its starts the noice untill i almost stop. if i put it in neutral it doesn't make a sound. its as im going into 1st/ untill i almost stop w/ it in first. but it only does it on the downshift.
and if i went and got in my car and took off right now it wouldn't make a sound either.
Old Jul 17, 2007 | 03:06 PM
89N10GTA's Avatar
Car: 1989 GTA
check the fluid and or change it sometimes a low level will cause the trany to make noises. but it kinda sounds like the first gear synchro if it has poped out of gear on you. if you let off the gas in first or any gear after a hard take off and it pops out then the synchro's are shot.
Old Jul 17, 2007 | 11:13 PM
Car: '91 RS
now how do i go about changing/adding fluid to my tranny....will auto tranny fluid work?
its not the synchro's then cause it didn't pop out of gear after i got on it and just let off the gas
Old Jul 17, 2007 | 11:23 PM
AssCloud's Avatar
Car: 87 GTA, 97 Formula
Engine: 350 TPI, 350 LT1
Transmission: T5, A4
Axle/Gears: 9 bolt 3.45, 3.42
I had a similar problem with my first T5. it would only get real bad "annoying" as my engine/trans temp started to raise. make sure youre trans isnt overheating causing everything to expand. Ive noticed on the two thirdgens ive owned that 1st and reverse are tricky, even with a brand new tranny. As for the noise i can't say, but first gear definetely likes to fight back when youre downshifting.
Old Jul 18, 2007 | 10:06 AM
89N10GTA's Avatar
Car: 1989 GTA
there are two big bolts on the trany case that you drain-fill-check the level with. my not sure where they are on that trany or what fluid goes in it. i would ask that question in the driveline board.
Old Jul 18, 2007 | 10:44 AM
molopaa's Avatar
Car: 83' Pontiac Firebird
Engine: 2.8 V6
If I remember correctly they are on the side of the tranny, about in the middle, maybe a bit back from the center length wise. They look like square bolts and are usually pretty tight.
And although this is a manual tranny, it uses Dextron 2 or up. Check your Haynes to be sure.
inferno15
Aug 29, 2015 01:48 AM
BitchinCamaro
Nov 28, 2001 01:51 PM
Amrish
Nov 9, 2001 11:33 AM
Amrish
Jul 16, 2001 02:16 PM
