Having trouble getting a voltage reading on my TPS
Old Jul 18, 2007 | 07:06 PM
Shroomie's Avatar
Car: 89 Camaro RS
Engine: 2.8L
Anybody have any tips on how to read the TPS voltage? I can't seem to fit anything in the back of the plug, and I've tried wedging a skinny piece of solder between the connectors but I can't get an accurate read. All I can get is 0.040v which isn't even close to what I should be getting.
And just to make sure I'm doing everything right: I'm running the multimeter between ground and the top connector on the TPS, right? The middle and bottom give me ~5v.
Old Jul 18, 2007 | 08:11 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: Having trouble getting a voltage reading on my TPS
I believe the top two are the right ones. I know that I'm not supposed to but my voltmeter's sensors have a point on them so I just penetrated the wiring insulation to read it that way, then I just put electrical tape over where the small holes are. You can also just add short lengths of wire between the TPS and the TPS connector to get a reading. I tried it that way, it's possible bit it was just cumbersome for me.
Old Jul 19, 2007 | 04:26 PM
Shroomie's Avatar
Car: 89 Camaro RS
Engine: 2.8L
I finally got it adjusted right. Turns out it was the middle wire and not the top one. It's running better but still not right. I think I'm down to just vacuum leaks, and possibly a bad IAC, now.
GTAman
Sep 21, 2015 09:57 AM
RyanJB
Sep 2, 2015 01:27 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
