Big Problem Need car for work tommorow! Please Help!
Old Aug 1, 2007 | 05:26 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Ok, I was sitting in traffic, it was 95 degrees F. The car was running roughly 100 Celcius, with 280 KPA of oil pressure. But all of a sudden, my oil pressure started dancing, and it started to run like crap. I mean, it has decent power until about 1400 RPM, then it just starts chugging, and popping like mad. I finally got to work, and left it there while I went and did my thing. But on the way home, it was worse, and progressed as I went.
It sounded like a stock car, so I was thinking that my exhaust could have finally broken off, and my O2 was all messed up, but when I finally did get home, I could smell the undercoating burning off the floor of the car, and my exhaust, pipe, cat, and everything were red hot. My dad told me it could be a stuck injector, but what else could it be? Intel is needed! Thanks much, KP.
Old Aug 1, 2007 | 07:08 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: Big Problem Need car for work tommorow! Please Help!
Sounds to me like your cat might be clogged, I would check that first.
Old Aug 1, 2007 | 07:13 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
I bet that your cat is clogged up/
Old Aug 1, 2007 | 07:52 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
Axle/Gears: limited slip posi 3.42
if it smelled like rotten eggs but sometimes it doesn't smell like that U could also tap it and hear for lose pieces. Another thing to check is if a vacuum line came undone it will make u run rich.
i didn't even noitcice it was u dude lol well good luck anyways. I also have a glowing cat but it's not clogged and i'm gunna run some vacuum tests tomorrow. Hopefully if i can get off work early.
Old Aug 1, 2007 | 08:26 PM
Kevman's Avatar
Engine: 2004 LQ4
I've heard about the cat problem, but that would've happened over time. This seems more like a ignition/fuel problem then anything. You can acually hear it blowing into the exhaust manifold. It's a very distinguished sound. But I'll have my cousin look at it tommorow, he knows 60* V6's better than I would, I just know big block Fords...
Hey Rover, you wouldn't by anychance know anyone with a 3.4 for sale, would ya?
Old Aug 1, 2007 | 11:55 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
Actually no man i got lucky kinda and got one from J & B's but who know's on kijiji someone's looking for one to unless that is u. If i hear of anything though i will let u know.
Old Aug 2, 2007 | 06:37 AM
Kevman's Avatar
Engine: 2004 LQ4
Haha yea that is me on Kijiji, I've been posting those ads for 4 months, and I've only found 1, but his fiance wouldn't let him sell it.
Old Aug 2, 2007 | 11:26 PM
ROCHEAD!'s Avatar
Timing, (distributer) Sparkplug wires, Fuel pump, injectors, Fuel filter, Map sensor, feul pump relay. ALll of which i told you to check already, before Steve gets his grubby little hands on it. hehehehehhe. I know hell read this but, he likes V6's, and he thinks his is fast. heheheh
Old Aug 3, 2007 | 06:17 AM
Kevman's Avatar
Engine: 2004 LQ4
Yea but 12 people have told me what a cat sounds like when it gets gummied up, and it's exactly what happened, a total loss of power, and it doesn't want to go anymore. I already bought the new cat, it was only 100$ anyway.. But if this doesn't do anything, It's probably a motor problem.. We'll see...
Old Aug 3, 2007 | 08:44 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
it's 40$ or less if you get a new one put on... at any muffler shop.
Old Aug 4, 2007 | 04:32 PM
Kevman's Avatar
Engine: 2004 LQ4
Well turns out that the cat is not the problem.. Cut it off, fired it up, and still, the exact same problem... I'm very lost...
Old Aug 4, 2007 | 05:33 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
If you ran it with just an open y-pipe then you may not have very much back pressure. If you loose alot of back pressure then you loose alot of torque. Put the new cat on and see what happens.
Old Aug 4, 2007 | 08:56 PM
Kevman's Avatar
Engine: 2004 LQ4
Well, the cat acually had nothing left, the honeycomb stuff was completely blown apart. It could've been one of the problems, but it seems more like a fuel problem because passed 2100 RPM it completely dies... I'm checking compression tommorow.
Old Aug 4, 2007 | 10:06 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Check fuel filter too..
Raf
Old Aug 4, 2007 | 10:15 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Have you snapped a fuel pressure gauge on it and then revved it up to see the pressure at that specific rpm??
Old Aug 4, 2007 | 10:34 PM
Kevman's Avatar
Engine: 2004 LQ4
No, not yet.. But I'll definatly check that tommorow..
LuvofJah, I changed the fuel filter 2 months ago.
Old Aug 5, 2007 | 01:37 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
fuel pressure is where it's at...
That's why your oil pressure started dancing. You were running out of gas...
Just had this happen to a friend's TBI 350. Word to the wise; buy the replacement fuel pump for the 89 Turbo T/A. It's available at the auto parts store for 10 bucks more than the V6 pump standard on our cars. They keep it in stock because it is also the pump used on the first Vortech pickup truck engines...
Old Aug 5, 2007 | 01:59 PM
Kevman's Avatar
Engine: 2004 LQ4
I got a reply on 60* V6.com about a oil sending unit causing it aswell. I'd much rather check that first, than ripping apart the tank to get to the sending unit. I got a pic of the plugs, and I did a compression test. My results were EDIT : I forgot to mention I changed the plugs 1000 km ago.
1 - 120 Psi
2 - 120 Psi
3 - 120 Psi
4 - 120 Psi
5 - 120 Psi
6 - 120 Psi
Old Aug 5, 2007 | 03:31 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
You don't have to rip into the tank to check fuel pressure...
You just need a fuel pressure gauge (about 35 dollars) from the auto parts store and plug it in at the back of your fuel rail. You should have over 40 psi most of the time. It's very easy to do...
My suggestion about the fuel pump to use when replacing your old one was just for general knowledge. If you condemn your pump you are better off to replace it with that one than your exact replacement.
Old Aug 5, 2007 | 07:16 PM
Kevman's Avatar
Engine: 2004 LQ4
Haha!! It's the Mass Airflow sensor. I pulled off the hose going to the throttle body, and fired it up, 3800 RPM and no problems! I'm so happy it's not the fuel pump. Thanks guys! KP.
Old Aug 7, 2007 | 09:50 AM
ROCHEAD!'s Avatar
You won't be laughing when you find out the price of one of those MAF. I believe i bought one new before in the upwards of 350-400 new of course. Junkyard time!
Old Aug 7, 2007 | 10:22 AM
Kevman's Avatar
Engine: 2004 LQ4
More like time to rip out the motor, trans, and rear end and putting in a carb'd 350, 5 speed trans, and 10 Bolt POSI. Mom is really starting to **** me off, aswell.
Old Aug 7, 2007 | 11:42 AM
KrisW's Avatar
Engine: 2.8/TBI/TPI
76 dollars for a new one on partsamerica.com. That's advance auto parts and Kragen locally.
Lifetime warranty.
Hope this helps!
Old Aug 7, 2007 | 04:32 PM
Kevman's Avatar
Engine: 2004 LQ4
Ok, new cat, and I cleaned the contacts on the Mass airflow. Now I'm extremely pissed off (excuse my french) So I'm taking it to a GM Dealer so they can look at it! I'll update this tommorow!
Old Aug 7, 2007 | 06:25 PM
grimmcs's Avatar
Car: 91 Camaro
I would say replace the MAF and see if that fixes it. The problem with it might not have been the contacts.
Old Aug 7, 2007 | 09:06 PM
Kevman's Avatar
Engine: 2004 LQ4
Yea, but if I have it plugged in, it runs the same with no check engine light, but yet, unplugged, the check engine light is running strong, and the car runs the exact same, with less black smoke.
Old Aug 12, 2007 | 06:18 PM
Kevman's Avatar
Engine: 2004 LQ4
Here's a doozey for you! We were getting 18-25-35-40 Psi and it kept going in between those numbers. A few vacuum hoses were off and stuff, and I need new plugs. The guy I brought it to was starting to take off the crossmembers and heat sheilds when he noticed the praline hose leading to the tank was twisted 3 times around. He undid it, and put it back on straight.
The car runs like a top, better than when I bought it!
Old Aug 12, 2007 | 10:01 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
good to hear dude.
u have a pm
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
