92 V6 5 speed tranny mount. Why so expensive? $200
Old Aug 4, 2007 | 05:08 PM
Firebat's Avatar
None of the stores(advance, napa, oreillys) sell a tranny mount for a 92 firebird v6 5 speed. The gm dealer does but they want over $200 for one. The automatic mount only costs $6. Anyone know where i can get a cheaper mount?
Old Aug 4, 2007 | 06:24 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: 92 V6 5 speed tranny mount. Why so expensive? $200
if you want the stock hydraulic mount that originally came on it, you're gonna have to spend the cash. It's a dealer only part that has been discontinued for production and that's the reason it's so expensive. The aftermarket has not made a mount that replaces it exactly yet. There are a couple of options for making an automatic one fit, do a search, there was a post almost exacly like this about 1 week ago.
Old Aug 4, 2007 | 06:45 PM
Firebat's Avatar
ok. found it. They really need to fix the search so that we can search titles.
Old Aug 11, 2007 | 02:07 PM
Firebat's Avatar
I ended up putting in a used V8 transmission crossmember brace and a V8 tranny mount. Made a world of difference. The car has always been (for the 5 years I've had it) a little jerky when shifting gears and its not anymore. Plus, it cost me altogether around $32.
Old Aug 11, 2007 | 02:09 PM
2tonedmaro89's Avatar
Car: '91 RS
Engine: 5.0L gross *** tbi
very nice as i have a v8 crossmember in my garage lol just havent had time to put it in yet
Old Aug 11, 2007 | 02:38 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
There are several difference mounts (as I came to find out). Check the following link for info, should you be interested.
https://www.thirdgen.org/forums/hist...ss-member.html
JamesC
Old Aug 12, 2007 | 02:16 AM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
i had to do this same thing because of the same problem last year.
the mount was too expensive, and i ripped through 2 used ones that i found online
so i finally switched to the v8 style with the secondary crossmember, ordered some poly biscuits and a poly mount from jegs
i thought the poly mount would transfer more vibration into the car, but the floating crossmember mounted on secondary biscuits offsets that dramatically
now the car is smoother AND the trans is mounted alot stiffer. now i get almost no shifter bounce through gears like i did before
Old Aug 12, 2007 | 05:29 AM
JamesC's Avatar
Originally Posted by Dizturbed One
i finally switched to the v8 style with the secondary crossmember, ordered some poly biscuits and a poly mount from jegs. i thought the poly mount would transfer more vibration into the car, but the floating crossmember mounted on secondary biscuits offsets that dramatically. now the car is smoother AND the trans is mounted alot stiffer. now i get almost no shifter bounce through gears like i did before
Should anyone be interested in the OE secondary cross member rubber insolators. I have a new set, brand new in the package. Cost + shipping.
JamesC
Old Aug 12, 2007 | 12:24 PM
Car: '91 RS
i DONT have that secondary crossmember. mines a single on. im guessing theres no differece from what i understand besides weight?(that link)
Old Aug 12, 2007 | 01:21 PM
Firebat's Avatar
I'm just using a single piece for the tranny crossmember and a $6 rubber motor mount.
Old Aug 12, 2007 | 01:47 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Hopefully no one will ever try to replace that big crazy mount again!
There are too many cars in the wrecking yard not to switch the crossmember out and just use a nice V8 mount.
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
angel2794
Sep 8, 2015 06:22 PM
IROCtometal
Sep 2, 2015 02:01 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
