Dist question
Old Aug 10, 2007 | 12:16 PM
Xoferif's Avatar
Car: '91 Camaro RS
Engine: 3.1L
Dist question
Aight, I've been trying to find pictures so that I can figure out the answer myself, but I haven't had much luck with that...
So, I own a 1991 Camaro RS with a 3.1 MPFI. When I bought the car, the kid I bought it from was going to do an engine swap...so, he had the 3.1 all disconnected. I've pretty much figured out where everything goes, and I was trying to start it last night...but it doesn't have spark. My question is....are there suppose to be two plugs going into the distributor? Right now, it only has one plugged in, and I can't find the second anywhere....I'm fairly certain that there should be two, but as I said....it's just not there.
Thanks in advance.
Old Aug 10, 2007 | 12:28 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Re: Dist question
Correction...
There are two plungs on the dist. Couldn't see the other one but feel it
Old Aug 10, 2007 | 12:54 PM
Xoferif's Avatar
Car: '91 Camaro RS
Engine: 3.1L
Re: Dist question
Still no luck in finding it, I've been over that engine countless times. I've followed all the wires to see where they plug in to with no luck. I have the wire that plugs in closest to the engine, but I can't find the one that's closest to the firewall. Where should it be coming out from? Anyone have a picture of it?
Old Aug 10, 2007 | 01:00 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Re: Dist question
There is a connection near the coil that goes to that one...
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
Re: Dist question
One set of two wires goes from the coil to the distributor plug in. It is a small say 12 in in length wire. Is very easly misplaced. Because it does not attach to the wiring harness. If you still cant find it give me your email and I will send some pics so you know what your looking for
Old Aug 10, 2007 | 01:05 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Re: Dist question
The black goes to the dist
Old Aug 10, 2007 | 01:11 PM
Xoferif's Avatar
Car: '91 Camaro RS
Engine: 3.1L
Re: Dist question
Mkay. You beat me to the pictures...I just went and took some myself.
That would explain it then, I'm missing that wire. Looks like I'm gonna have to take a trip to the junkyard.
Thanks again...it's appreciated.
Old Aug 12, 2007 | 12:56 PM
Xoferif's Avatar
Car: '91 Camaro RS
Engine: 3.1L
Re: Dist question
Went to the junkyard yesterday and got the parts I needed....she started right up and runs strong.
I'm surprised how easily it starts....
Old Aug 12, 2007 | 01:42 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Dist question
You will not only be surprised with the starting but how long it lasts. The 3.1 is a very reliable engine. I sold mine with 248,000 miles and it was still running strong.
apo_bailon15
Mar 28, 2016 05:20 AM
mddaniel
Sep 8, 2015 05:16 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
db057
Aug 22, 2015 08:17 PM
redmaroz
Aug 16, 2015 11:40 PM
