Putting in a new MSD GM blaster coil.
Old Aug 21, 2007 | 06:44 PM
Bazookajoe254's Avatar
Car: 86 Firebird
Engine: 2.8 V6
I'm all for doing the simple mods that all come together in the end for a overall better running car.
Do you guys think swapping in a GM Blaster coil is worth it on a daily driver.... that likes to see the higher RPMs sometimes?
I've allready got a -better than stock distributor- and some Accel wires that are 8mm spiral core.
I don't know the specifics on that stuff because my dad threw it on the car when we first got it and it didnt run and I didn't know alot about it back then. I'm not sure what the plugs are.
But overall do you think a MSD blaster coil - the GM dual connector one - would be a worthy improvement for the $45.00?
Old Aug 22, 2007 | 09:21 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Putting in a new MSD GM blaster coil.
I like the MSD stuff, personally. If it's a bolt on then you have nothing to lose. It's a high quality piece and can do well no matter what your set up.
Old Aug 23, 2007 | 05:06 PM
Shroomie's Avatar
Car: 89 Camaro RS
Engine: 2.8L
I put one in my car when I did my plugs/wires/cap & rotor. Dunno if it helped much, seeing as my car doesn't quite run right now.
Old Aug 30, 2007 | 08:37 PM
H8TRAFIC's Avatar
I put one on my car along with Accel wires and NGK plugs - it seemed to work ok.
Old Aug 31, 2007 | 12:22 AM
badinfluenceRS's Avatar
Car: 1994 Trans Am - 1992 Firebird
Engine: LT1 5.7 V8 - 3.1 V6
Axle/Gears: 3.42 / LSD
Unless your running FI i dont think aftermarket ignition will get you any improvements over stock quality parts...
but I always buy MSD stuff anyways
Old Sep 3, 2007 | 04:54 PM
Car: 86 Firebird
Engine: 2.8 V6
It's MPFI.
Old Sep 3, 2007 | 06:07 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
from previous posts ive read on here about this kinda stuff, just a coil or whatever wont hurt, but it doesnt really help too much unless you put in an ignition box and all that as well. ive had both a GM replacement on mine and an MSD blaster coil, i didnt really notice any difference. I guess, unless youre going all out id just stick w/ the GM replacement, unless $$ isnt really a big deal, lol.
Old Sep 3, 2007 | 10:44 PM
Car: 86 Firebird
Engine: 2.8 V6
Well I don't NEED to replace it, nothing is wrong with the one I have. I was just looking for an improvement. But from what I've been hearing it doesn't sound like it's something worth going for right now.
Thanks for the info guys.
stalkier
Dec 6, 2015 11:25 PM
Thornburg
Aug 30, 2015 08:05 AM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
