blower motor and AC controls question
Old Sep 23, 2007 | 05:30 PM
micali's Avatar
Car: 1988 sport coupe
Engine: 2.8
Transmission: 700 r4
I have an 88 camaro but the blower motor from Autozone doesn't even come close to fitting. I started to look around on this site at other camaros and it looks like I should be using the 83 camaro blower motor. What gives. See my first pic on how unclose the fit is. Also, I only had one place on the new blower to hook up the power to and no ground.
The second one is an extra plug just sitting there, what does it go to.
and the last pic is a capped off vacume line. I have no clue what this goes to. It is sitting on top of the blower housing.
I wired the blower motor up to work but inside the car I only have air blowing out the defrost. Doesn't the controls for the ac, to vent, defrost work off vacume? I don't hear anything sucking when I move the lever. Any suggestions?
Attached Thumbnails blower motor and AC controls question-blower-gap.jpg   blower motor and AC controls question-extra-line.jpg   blower motor and AC controls question-blower-vacume.jpg
Old Sep 23, 2007 | 06:18 PM
micali's Avatar
Engine: 2.8
Re: blower motor and AC controls question
I found out that my 88 use's the 86 blower motor. Does anyone have one that is out of a parts car? They are $60.00 bucks new. Don't have that kinda dough. If not I'll make this one work.
Old Sep 23, 2007 | 06:27 PM
micali's Avatar
Engine: 2.8
It looks like I have to use the blower motor that says without A/C. That's strange, I have factory AC.
Old Sep 23, 2007 | 06:42 PM
firstfirebird's Avatar
I've alsways just pulled them out of the JY when I had one go bad. Just ask for a test before you leave and they can hook it up to 12v to confirm. I think I brought the blower with me last time, and pulled it outof an entirely different vehicle, GM is known for using parts across many body styles.
Old Sep 23, 2007 | 08:02 PM
micali's Avatar
Engine: 2.8
what difference will it make to use the blower motor that says with out AC? Also does anyone know where to hook up the vacume line for the vent controls on the engine side? I have a lone vacule line that is capped off and don't know where it is supposed to go. I believe it is for the controls inside the car. See pic above.
Old Sep 23, 2007 | 08:21 PM
There's a tee fitting on the back of your UIM. One side goes to the brake booster, the other to the controls. See if that tee has either been replaced with a single fitting, or has a cap on it.
You can install the non-A/C blower, and try it, it's not going to hurt anything.
Old Sep 23, 2007 | 08:28 PM
micali's Avatar
Engine: 2.8
That T on the back of the motor is quite big. The line I have is 1/4" atleast. The one side is going to the brake booster and the other is going to a soft line but I'm not sure where to.
I'll check it out later and see what I can find.
Old Sep 23, 2007 | 08:58 PM
micali's Avatar
Engine: 2.8
couldn't wait until the morning so I went out and found that the line has another round type T and then from that is a short piece of hose with this tiny reducer that must act as a restricter for the controls in the car. I unhooked the line from the reducer and noticed that it barely pulls any vacume. I uncapped the other line and hooked it up to the restricter and tried the controls inside the car and nothing. I didn't hear any vacume leaks inside the car.
I could have mess'd with something when I pulled the console out so now I will have to check the controls inside the car. Man this stinks.
also both of those lines go into the car fromt he same spot in the firewall.
Old Sep 23, 2007 | 08:59 PM
That reducer is a check valve.
Old Sep 23, 2007 | 09:18 PM
micali's Avatar
Engine: 2.8
ok, it must be stock then. so the inside controls don't need alot of vacume? That little thing really restricts the suction. I wonder what else inside the car I should look for?
Old Sep 23, 2007 | 09:33 PM
Did you chack fuses and the such?
Not a lot of vacuum is needed to contol the HVAC, have you sever see the back of the controls? There is a few VERY small lines that feed them.
Old Sep 24, 2007 | 05:51 PM
micali's Avatar
Engine: 2.8
fuse is good. I tried hooking up the extra line and nothing. It looks like everything is hooked up and nothing is missing. I do not see were those black lines meet up with the controls.
Old Oct 2, 2007 | 06:49 PM
micali's Avatar
Engine: 2.8
I found the vacume connection that comes into the car and found that it was unplugged. They work great now.
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
