what does this mean, fan relay
Old Oct 6, 2007 | 01:50 PM
micali's Avatar
Car: 1988 sport coupe
Engine: 2.8
Transmission: 700 r4
I grounded the green and white wire for the fan relay and the fans came on. Does this mean the relay is good or bad? I bought a new one just in case.
Also, what is the relay next to the fender, on the firewall? That relay also has two green/white wires and I tried grounding them and nothing happened. Thank goodness because that was the wrong relay.
I had read in an earlier post that there would only be one relay with a green and white wire. Someone was wrong.
Old Oct 6, 2007 | 02:04 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: what does this mean, fan relay
That was probably me.
Anyways, if the fans turned on, your relay is good.
Old Oct 6, 2007 | 03:15 PM
micali's Avatar
Engine: 2.8
so what else should I look for?
Old Oct 6, 2007 | 05:33 PM
Toehead's Avatar
The fan swith or wiring is probably bad at this point.
Old Oct 6, 2007 | 05:34 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
I have the same problem. Ive replaced every sensor and relay possible for the fan and it still doesnt turn on but when i jump it from the battery it turns on.
Old Oct 6, 2007 | 05:39 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
get a toggle switch until you fix this, or run a wire from one of the lines that turn on power when your key turns.
Old Oct 6, 2007 | 05:44 PM
micali's Avatar
Engine: 2.8
I've wired a toggle switch from the green and white wire and they come on when I flip the switch. Where is the fan switch? I haven't replaced the temp switch on the intake yet either.
Falcon50
Aug 22, 2020 03:26 PM
sheachopper
Jul 31, 2019 11:27 AM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
