Changed coil now big problems!
Old Oct 18, 2007 | 01:51 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Hey guys, just changed my coil today and now i'm having quite a problem. It's overheating, check engine light is on, and it's not good. I might've broken a vacuum line but i need to further inspect this, i'll keep this posted up.
Old Oct 18, 2007 | 02:01 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: Changed coil now big problems!
What are the codes. Sounds like you may have messed up something. Check and see if the wire for the fan switch (backside of the passenger head) is in place. I know that I was messing around that area and messed up the connection.
Old Oct 18, 2007 | 09:49 PM
Kevman's Avatar
Engine: 2004 LQ4
I'll have to check it tommorow, I just worked six hours after school of getting yelled at by people who are not my boss, so it's not a good idea to work on the furbird tonight.. I'll check that out though, it would explain the 125 Celcius temp.
Old Oct 19, 2007 | 08:25 PM
Kevman's Avatar
Engine: 2004 LQ4
Ok, fan works. Car hit 125* Celcius today. I fixed some broken vacuum lines, had to buy a new T-fitting, some brand new tubing, and a headache of remembering where it all went. But it got back together, test drive is tomorrow. Thanks, KP
92camaroJoe
Jul 29, 2023 07:57 PM
Terrell351
Jun 13, 2021 01:13 PM
db057
Aug 22, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
