Code 13
Old Nov 1, 2007 | 05:37 PM
89camaroRS6's Avatar
Code 13
i recently have been getting the code 13 o2 circuit any ideas on what it could be?
Old Nov 1, 2007 | 05:49 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: Code 13
Bad O2 sensor.
Old Nov 6, 2007 | 09:12 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: Code 13
On open , short to ground or short to power in the O2 sensor circuit. That's the only thing our cars check for on the O2 ckt. There is no logic check on it.
Old Nov 7, 2007 | 01:37 PM
Re: Code 13
how do i fix it?
Old Nov 7, 2007 | 02:04 PM
Xoferif's Avatar
Car: '91 Camaro RS
Engine: 3.1L
Re: Code 13
First, I'd make sure that the wire that runs to the O2 sensor didn't come into contact with the exhaust and melt -- if it did then you'll just need to replace the wire. If it didn't, then you'll probably need a new O2 sensor. Don't get a remanufactured one.
Old Nov 9, 2007 | 01:50 PM
Re: Code 13
thanx will try it
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
