Should I get a Custome Tune?
Old Nov 4, 2007 | 12:34 AM
DaSkinnyGuy's Avatar
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
Well heres the deal. I have a 92 Firebird 3.1L V6 with CAI, Headers, High flow cat, 2 1/2" flowmaster 80 series cat back, and a 180 themo. Next weds the car will be going to JSPerfomance to have a header installed. The cars idle has been running a lil rough and the cars running rich. They do custome tunes and have a dyno. Do you think I should put the car on the dyno and get a custome tune. I do want to get the car running stronger, and maybe make some tweaks to the computer. And any idea what HP I can pick up with the mods I do have.
Old Nov 4, 2007 | 09:19 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: Should I get a Custome Tune?
You really don't need to tune these cars until you go internal or FI. Can that shop tune OBDI though?
Old Nov 4, 2007 | 03:24 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Why even consider having the shop tune it when you can get a willems burner and an aldl adapter so you can datalog for $120 and do it yourself. All a shop will do is tune it for PE and charge you up the a** while leaving the other tables untouched.
Old Nov 4, 2007 | 09:35 PM
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
As of what I know they can tune any thirdgen. Well I thought it would be worth a shot. Anyhow I do need my idle to be fixed, its running higher than it should be, its a 900rpm when its usually at 620-650. And its running rich.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
Deemax
Sep 12, 2015 06:53 PM
Ranbo108
Sep 9, 2015 12:20 PM
