Is my blower motor going out or what?
Old Nov 9, 2007 | 05:47 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
Figures...just when winter is coming on. Whenever I'm driving with the blower on, no problem. When I come to stop sign or red light, the voltage goes down and the car seems to bog. Weird huh? The alternator is new as well as a tensioner pulley. Maybe its time for a new blower motor or perhaps the resistor pack is going out. The problem does'nt occur under the same conditions if I turn the climate controls all the way off. Any thoughts?
Ken
Old Nov 11, 2007 | 09:54 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Is my blower motor going out or what?
Just because the alternator is new doesn't mean it's any good. Either you don't have a good alt or batt, or one of your wires between is no good. The problem is that with the blower on, you're pulling more current than your current alternator can handle, and it's killing your power output. Yes, the blower motor may be overdrawing current, or the resistors may be bad, but I would try a different alternator first just to see, since it shouldn't cost you anything because it is under warranty, right?
There are ppl on here who have gone through 5 or so parts store alternators before they have found a working one, FYI.
Old Jan 1, 2008 | 11:14 PM
derfss2003's Avatar
Car: 84 camaro z28
Engine: 5.0 HO
I would have to agree with Maverick H1L. I had a problem with my 84 dropping voltage when coming to a stop or slowing down and I had to replace the alternator twice to fix the issue. for some reason the first alternator was bad out of the box.
Old Jan 1, 2008 | 11:59 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
i had a new alternator go out 1 week after purchase the bearings went out... best to have them bench tested at the parts store when purchaseing
Old Jan 2, 2008 | 11:00 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Did you make sure that the pully that is on the new alternator is the same size as the old one. I got 3 in a row that had a smaller pulley than was on my original, which resulted in belt slippage and low voltage at idle.
Old Jan 4, 2008 | 12:36 AM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
change the pulley from old one to new one = fixed
Old Jan 4, 2008 | 07:56 PM
ken3983's Avatar
Well....the pully is the same diameter, but they screwed me. The alternator they gave me had a 5 groove pulley instead of a 6 groove. Needless to say. it was tearing my belt all to pieces. I took it back and they put a 6 groove on it.
Ken
Frozer!!!
Jan 19, 2024 04:55 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
zayne0
Aug 24, 2015 07:22 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
