Under Hood Parts Delete
Old Jan 2, 2008 | 08:16 AM
Shookum2004's Avatar
Car: 1988 Camaro SC
Engine: 2.8v6
Transmission: 5spd manual
I am looking to delete as much useless stuff out of my engine bay as much as possible. I do not care for the A/C and things like the vacuum canister and the silver cylinder on the passenger side of the engine bay... can i get rid of those?
I see a head gasket repair in my future and I want as little in the way as possible. Thanks!
Old Jan 2, 2008 | 12:29 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: Under Hood Parts Delete
Depends upon the use of your car.
I belive in the body section, there is a "weight reduction" thread which you can get into.
AC
Smog
Power steering
charcole canister
cruise control
relocate battey to rear of car
electric water pump
wiper motor/linkage
list can keep on going if you wish
Old Jan 4, 2008 | 09:46 AM
xbcrguy182x's Avatar
Is the charcoal canister important? What would happen if someone removed it?
Old Jan 4, 2008 | 10:13 AM
Dale's Avatar
Engine: 350 S-TPI
It vents gas tank fumes into the motor while under throttle.
Some have removed it with sucess. I have heard some havent.
Old Jan 4, 2008 | 09:14 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
if youre looking at a head gasket replace, and you wanna delete whatever you can..... it depends on your climate as well as what state you live in. in a perfect world you can get rid of your heater hoses, EGR, AIR, A/C. all those will get in your way. the charcoal canister wont really cause any problems other than 2 vacuum lines that take 2 seconds to pull off. the rest that Dale mentioned is all up to you if you wanna live w/o P/S, spend the money on an electric waterpump (and can find a way to delete the current system) and if you never drive your car in the rain or dont mind a dirty windshield occasionally.
Frozer!!!
Jan 19, 2024 04:55 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
1nastygta
Aug 8, 2015 07:38 PM
