timing chain issues
Old Nov 10, 2007 | 03:02 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
timing chain issues
this might be a problem. looks like my timing chain it skipped teeth, which explains why it wont run. but its not just a timing chain, my guideplate for the timing chain is trashed. one side of the guideplate looks like it was wore down to a smooth surface. does anyone know where i can get a new guideplate? i'll be replacing the timing chain too, so if there's a kit for this i'd be interested.
Old Nov 10, 2007 | 06:30 PM
Xoferif's Avatar
Car: '91 Camaro RS
Engine: 3.1L
Re: timing chain issues
Should be able to get 'em from any parts store...
I prefer Napa, but to each his own...
http://www.napaonline.com/masterpage...+Set+-+3+Piece
http://www.napaonline.com/masterpage...g+Chain+Damper
If you're thinking about just replacing the chain, I would strongly advise against it. Especially if the chain skipped...and often times, the kits are just a very small amount more than an chain alone...sometimes even a little bit cheaper.
Anyway, incase I didn't stress it enough, the sprockets should definitely be replaced.
Old Nov 11, 2007 | 07:27 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
I got mine from the dealership, genuine GM parts.
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
86Base
Aug 8, 2015 01:34 PM
