V6 Rearend ?
Old Nov 19, 2007 | 05:10 PM
vintageisbetter's Avatar
Car: 1992 Firebird, 1953 CJ3B
Engine: 3.1
Transmission: 5speed
V6 Rearend ?
i just bought a 1992 3.1 firebird and im wondering if it has a posi-track, or another type of limited slip rear differential?
anyone know?
thanks
Old Nov 19, 2007 | 05:15 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: V6 Rearend ?
Easy way to tell is to lift the rear of the car off the ground and spin the tires. if they spin in the same direction then you have posi, if they go opposite of each other then you have an open diff. Mine doesn't but I'm not sure if any V6s came with posi from the factory.
Old Nov 19, 2007 | 05:18 PM
Engine: 3.1
Re: V6 Rearend ?
good idea. ill give it a try.
Old Nov 19, 2007 | 05:56 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: V6 Rearend ?
You did get the 28 spline axle shafts, and that can be just as hard to get as posi!
There's a nice zexel torsen unit for sale in the classifieds from a 4th gen. Buy that and it will cure your problem.
You probably don't have limited slip...
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
86White_T/A305
Aug 17, 2015 12:16 AM
