Rough Idle
Old Nov 19, 2007 | 10:33 PM
cre81r's Avatar
Car: 1992 Camaro RS
Engine: V6 MFI 3.1
Transmission: 700R
Axle/Gears: Stock 3.23
Rough Idle
Well my car has been idling rough ever seen since I got it.The tach is really jumpy between 750-1k when idling.What causes the tach to be jumpy?Vacuum leaks?PCV valve?Bad IAT?No SES light btw
thx for the help!
Old Nov 20, 2007 | 01:56 PM
chevybowtieguy's Avatar
Re: Rough Idle
start by cleaning your intake especially around where your throttle plate is, cuz a little carbon buildup right there will constrict airflow enough to make your car idle rough, or at a lower rpm than it should. also make sure to clean the idle air control ports on either side of your throttle plate too. thats a good place to start anyway, if that doesnt fix the problem a tune up (cap rotor wires and plugs) is the next step. i always try to start with the simple and least expensive fixes first. good luck.
Old Nov 20, 2007 | 03:06 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Re: Rough Idle
Take off the Air cleaner hoses going to the throttle body, clean EVERY Thing that has carbon on it. Mine was especially bad, since my PCV valve was stuck open all the time. Make sure to clean the butterfly. Also, change your cap, rotor, plugs, and wires.
Old Nov 20, 2007 | 03:20 PM
cre81r's Avatar
Car: 1992 Camaro RS
Engine: V6 MFI 3.1
Transmission: 700R
Re: Rough Idle
Well I was checking the car earlier today and noticed that where my pcv valve is at it's leaking oil.Also checked the IAT sensor when I was cleaning my air cleaner that there was a little metal thing that looks like it came off the sensor.How much would an IAT sensor cost?
Old Nov 20, 2007 | 06:18 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: Rough Idle
Do you mean IAC? Often times the source of an erratic idle is the IAC. Last time I had to replace mine it cost ~$40.
Old Nov 20, 2007 | 06:59 PM
cre81r's Avatar
Car: 1992 Camaro RS
Engine: V6 MFI 3.1
Transmission: 700R
Re: Rough Idle
Nah inside the air cleaner assembly there was the tip of the IAT sensor was broken.
Old Nov 20, 2007 | 08:26 PM
Bazookajoe254's Avatar
Car: 86 Firebird
Engine: 2.8 V6
Re: Rough Idle
I doubt the IAT would cause a rough idle.
But I could always be wrong.
Could be just a small loose vaccuum hose.
Old Nov 20, 2007 | 08:39 PM
cre81r's Avatar
Car: 1992 Camaro RS
Engine: V6 MFI 3.1
Transmission: 700R
Re: Rough Idle
Well I'm going to replace all vacuum lines this weekend along with the pcv valve.Hope this fixes it.Eveything else looks good.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
89fast5oh
Sep 8, 2015 09:55 AM
IROCtometal
Sep 2, 2015 02:01 PM
