i think its my fuel injectors?
Old Nov 18, 2007 | 06:55 PM
salvamex89's Avatar
Car: 1990 pontiac Firebird
Engine: v6
wats do i do
i have a 90 firebird v6 .31 i think but anywayz evrytin is koo but like wen its cold out the rpm meter goes up automaticaly and makes the car go as if i was pushing the gas....nd now wen i turn it on the chek engine light flashes and the car rumbles or shakes a lot and i think its the fuel injectors wat do i do?...
Old Nov 18, 2007 | 09:45 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: wats do i do
Is it just me or was that a little hard to read?
I would check you codes first to see what sensor/s might be bad. If your SES light stays on there is something not working right. Here is the tech article on how to do that--> LINK.
Old Nov 18, 2007 | 09:56 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Re: wats do i do
Nope, it's not you, that's hard to read. I think i pulled a muscle trying to read that.
Old Nov 18, 2007 | 10:11 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: wats do i do
Check your codes first with grimmcs link. No offense but please type with some grammar, its alot easier for people to read any future questions.
Old Nov 19, 2007 | 05:30 PM
salvamex89's Avatar
Engine: v6
whenever i turn on my car now it shakes and rumbles and im scared to stop while driving for it may turn off. The rpm meter goes to about 2 when i put the car in park and the car wants to go forward. When in drive and at a complete stop it stays at 1 rpm and really wants to move forward. when parked and the meter says rpm 2 It sounds as if im pushing the gas. And ive noticed that sometimes the pedal for the acceleration seems easier to push in at times and hard at others. What could this be because i really love my car and i dont want to sell it?
Old Nov 19, 2007 | 06:14 PM
grimmcs's Avatar
Car: 91 Camaro
Re: i think its my fuel injectors?
Like I said in your other thread, about the same problem, check your codes and get back to us. It sounds as though one of your sensors has or is going bad. It might be the IAC. I wouldnt even think about selling.
Old Nov 19, 2007 | 08:37 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: wats do i do
The first thing I suggest is to type clearly. It's hard enough to try and diagnose a problem over the internet with nothing but a description, but when people have to try to decipher what your writing, 90% will go onto the next post. If you want proof, look at your view to reply ratio..including this post you have 4 replies and 71 views, that means 67 people just moved on.
As for the car, check the codes stored in the ECM and let us know what they are. When your check engine light comes on, the ECM has detected a problem with the engine controls and is trying to let you know something is wrong. Pull the code and we can try to get you going down the right track.
Old Nov 19, 2007 | 09:33 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
Re: wats do i do
sounds like a transmission problem to me.
Old Nov 19, 2007 | 10:09 PM
Bazookajoe254's Avatar
Car: 86 Firebird
Engine: 2.8 V6
It could even just be your TB plate getting stuck too far closed and getting stuck out ie. the low and high RPMs - that can even trip a code sometimes.
There are a ton of simple things it could be, go over the basics first.
IAC - clean it or get a new one.
If your car has a MAF - clean it or get a new one.
Check all your vaccuum lines. And check them again. And again.
Check your EGR valve - maybe yours is electric, if it is, I don't know how you'll do that, but if it isn't, its easy to check.
TPS - adjust it or get a new one and adjust that one, too.
All of the above things can lead you to a funky idle. Pick up a Hayne's manual if you don't allready have one - they make life much easier.
Old Nov 19, 2007 | 10:18 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
If I had to guess, I would say english is his second language, at least he's trying. As far as your problem, sounds like a throttle position sensor to me, had the same problem with my Jeep. I cleaned the contacts on the tps on the Jeep and that fixed the problem for me.
Old Nov 22, 2007 | 02:48 PM
salvamex89's Avatar
Engine: v6
i chekd the code but im not that good at this but it flash three 12s first then a 5 another 5 then another 5 but i dont no im guna do it again tommrw with someone who knows to make sure.
Old Nov 22, 2007 | 06:37 PM
Car: 86 Firebird
Engine: 2.8 V6
The 12 is always there, thats normal.
And each number after that should repeat 3 times.
Old Nov 23, 2007 | 07:17 PM
salvamex89's Avatar
Engine: v6
well yea but i took it to the gm dealer they looked and it was my fuel injectors.....o and i hvae a question i did the code test and there a little box that was diconnected it has 7 like connectors that go into a slot 4 on top and 3 under it....i connected it back to where it seemed to fit but wenevr i put the keys in it makes a loud beep noise but when it isnt connected no noise. wht is thta?
Old Nov 24, 2007 | 12:19 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I would think that is a "reminder" buzzer. I disconnected mine, but it lets you know that the lights are on, seatbelt is not fastened, and keys in ignition when the motor is off and, IIRC when the door is open. I don't have a working seatbelt warning light in the dash (Dakota Digital) and the seatbelt warning won't stop.
Old Nov 24, 2007 | 01:36 PM
salvamex89's Avatar
Engine: v6
ooo! ok so it doesnt matter if it connected or disconnected alright. well i found out its my fuel injectors...what do i do?
Old Nov 24, 2007 | 02:09 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
You can order new injectors, get ones from a JY for cheap, or get the ones you have right now rebuilt which shouldn't cost that much. Have you removed the injectors before?
Old Nov 24, 2007 | 03:49 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Did anybody else catch the part about a flashing check engine light?
A flashing check engine light indicates that the computer has failed internal diagnostics on the integrity of its programming. The car then runs in complete limp home mode bypassing the PROM.
This is usually due to a loose memcal or a bad ECM.
Old Nov 24, 2007 | 05:32 PM
salvamex89's Avatar
Engine: v6
no i havent removed them before but im sure ill be able to do it with my dad...so ok ill go to a junk yard...and as for the check engine light you say its a loose memcal or Bad ECM sorry that i dont know much about cars but what does ECM stand for?...and memcal?
Old Nov 24, 2007 | 05:48 PM
Toehead's Avatar
Just to be clear.. The check engine light is flashing while the car is running?
The memcal is a small board that contains the PROM for the car. The PROM is a chip that stores the code to run your car. If you look at the ecm, it will have a small cover on it. You can remove this cover and visually inspect the memcal.
Old Nov 24, 2007 | 06:04 PM
salvamex89's Avatar
Engine: v6
it only flashes sometimes when it shakes and wants to turn off
oo ok so i could chek the memcal...sorry but what the ECM...im not familiar with the short terms sorry...that way i can check it...and what im i looking for when i look at the memcal?
Old Nov 24, 2007 | 06:19 PM
Toehead's Avatar
The memcal is removable... It is in a socket. Sometimes it gets loose.
The ecm is a silver box under the passanger side kickpanel. Remove it... YOu need a 7mm socket. It will drop down. Remove the cover, and look at the memcal. You might even try removing it and reseating it.
Old Nov 25, 2007 | 02:07 PM
salvamex89's Avatar
Engine: v6
ooo....ok i c alright ill do that thanks
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
