Pulley's Making Noise
Old Nov 22, 2007 | 10:57 AM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
It seems like either my Power Steering or Water pump pulley is making a loud noise. Ive sprayed it with WD-40 and it didnt do anything. I just replaced the belt and belt tensioner afew months ago. Does anyone know how to fix this?
Old Nov 22, 2007 | 02:51 PM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
Re: Pulley's Making Noise
Its probably not the pully probably the pump themself. Probably going to have to replace them. I would lean toward your water pump first
Old Nov 22, 2007 | 03:09 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Is there any way that i can test it first? i have to drive 240 miles each way to school and back and i dont wana be stranded. The temp guage is still where its always runs at.
Old Nov 22, 2007 | 07:19 PM
kurfbird's Avatar
See if there any play up in down on the water pump. If any play it will need to be replaced. Water pumps are under 35.00 . also check weep hole for leaks
Old Nov 23, 2007 | 02:12 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Thanks for all the advise guys, i drove the car today about 40 miles and the noise has gone away, im hoping it was just because it was 30 degrees yesterday.
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
BlackBoulder
Aug 11, 2015 11:15 PM
