timming question??????
Old Dec 14, 2007 | 03:28 PM
ossseo28's Avatar
Car: 1992 camaro
Engine: 3.1 v6, CAI
Transmission: t5
Axle/Gears: eaton posi
during the summer i had to replace the distributor gasket do to a small oil leak. and in the proccess i replaced the intake manifold gaskets and had to remover the rocker arms and push rods so in the end i had to redo the timing. but since ive done it ive noticed my car will idle at 1500 rpms then go to 700 once its warm. could it be that i still dont have my valves set right? or is it that timming is still off? What would be the best timing setting for the car to get most performance. right now i have it at about 12*, but it doesnt seem right do to high idle. also since im gonna redo the valves and stuff next weekend after i put in a new oil pan, what would be the best way to go about pollishing my intake? thanks for the help.
Old Dec 14, 2007 | 08:05 PM
fictmich's Avatar
Car: 1991 firebird/1990 firebird
Engine: 3.1
Axle/Gears: 3.23:1
Re: timming question??????
So you're saying that when it starts it is at 1,500rpm then slowly works it's way down to 700rpm right? If that's the case, that's normal for what I've seen with my car. I have the timing and such all set to spec on mine. So either that's normal or there's that off chance that we both share the same hidden problem.
Old Dec 14, 2007 | 08:18 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
12-1500 @ idle is normal operation,normal timing is 6*,later jimmy
Old Dec 14, 2007 | 08:21 PM
Bazookajoe254's Avatar
Car: 86 Firebird
Engine: 2.8 V6
12-1500 seems high for a warm idle. It is normal for a cold start idle though. Like in the morning, it'll take my car a minute of running to let the idle start to slowly drop, but once I'm goin, it'll be down to 800.
If thats what you're experiance, it's normal. What changed? What was it doing before you replaced what you did?
Old Dec 14, 2007 | 10:33 PM
ossseo28's Avatar
Car: 1992 camaro
Engine: 3.1 v6, CAI
Transmission: t5
before it would idle at 700 rpm, no problem, but that was also in the summer. I thought it was just just it being colder now, since i live in MN, havent driven it since snow but before it did snow it was pretty damn cold and thats when it started. My dad thinks its the timing is still a bit off, but were both not mechanics and im only 16 so we dont have to much exp. Is 6* BTDC a good place to be at like he has his, just want to squezze every bit of power i can out of it
Old Dec 15, 2007 | 12:21 AM
molopaa's Avatar
Car: 83' Pontiac Firebird
Engine: 2.8 V6
Retarding your ignition to 6* BTDC will cause you to lose your power and it's not the correct setting anyways.
The stock setting IIRC is 10* BTDC, but you can probably take it back to 12* like you have now, if you use gas that has the octane rating to not start knocking.
Last time I adjusted my timing, it had slipped to 4* and advancing it to 10* made a big difference. Better throttle response and better mileage. So definitely don't retard yours to 6*.
Old Dec 19, 2007 | 05:08 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
10 degrees is right, 6 degrees is what the v8's run. i usually run mine around 12 degrees too and it seems to like that the best for 87 octane.
Old Dec 19, 2007 | 09:09 AM
fictmich's Avatar
Engine: 3.1
Axle/Gears: 3.23:1
I am also from the land of snow and ice and it will idle a little higher (up around 1,500rpm) when you first start it up and it's cold out. That's just what it does, there's nothing wrong with it. Keep the timing at 10 degrees unless the engine is modified to the point where it actually requires that it be set differently.
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
TheExaminer
Aug 19, 2015 10:07 PM
redmaroz
Aug 16, 2015 11:40 PM
