please help me!
Old Jan 12, 2008 | 06:38 PM
92Birdofprey's Avatar
Car: 92 Firebird
Engine: 3.1
Axle/Gears: stock, dynomax turbo exhaust
please help me!
Hey guys I know this might be a stupid question, but I just bought some rims 15x18 5X4.75, the ones that fit our cars, what I want to know now is how are the other numbers going to look, or what am I looking for when I search for tires, for example (P 245 / 60R15, Radial) what in the world does that mean? Can I put this tire with my rims or what does each number represent? Well I know what the 245 mean, but the rest I'm not sure, thanks guys.
Old Jan 12, 2008 | 06:51 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
Re: please help me!
They should fit but you might get some rubbing on the tire well.
245 = with of the tire ( how much meat is on the ground)
60 = the height of the tire (from the lip of the tire to the start of the tread)
15 = the size rim it goes on
Old Jan 12, 2008 | 08:59 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: please help me!
Let me ammend that just a little...
245 = width of the tire in millimeters (in this case it is 245 millimeters)
60 = aspect ratio; this means that the height is 60% of the width from the rim to the tread (in this case it would be 147 mm tall from the rim to the tread / sidewall height)
R = radial tire
15 = size of the rim diameter in inches (15 inch wheel)
Why would you buy a 15x18 wheel? Did you mean 15 x 8?
