Just got Dynomax Super Turbo Exhaust system...
Old Feb 3, 2008 | 11:03 AM
Kryppy's Avatar
Car: 87 Camaro
Engine: V-6 MPFI 2.8 liter
Transmission: 700 R4
I just got the Dynomax Super Turbo exhaust system setup. The only thing I can't quite figure out is exactly how the driver's side exhaust tip hanger/bracket hooks up to bottom of car. I know I could rig something but I'd really like to see how it's suppose to look (see what I'm missing). A picture would be excellent. Thank you ahead of time.
Old Feb 3, 2008 | 11:49 AM
UK Speedbird's Avatar
Car: 91 Firebird
Engine: 3.1L 191ci
Re: Just got Dynomax Super Turbo Exhaust system...
When i changed my rear exhaust kryppy the drivers side pipe had a hanger on the chassis rail type structure (the bumpers bolted to them) under the fuel tank it had 2 bolt holes already there. I couldn't use this hanger when I put my exhausts on because they were too far out board of it, so i made a custom hanger that used the same bolts/holes but fit the exhaust.
speed.
Old Feb 3, 2008 | 02:40 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
ii fabricated something using the bolts securing the rearmost crossmember- (thats what the rear bumper sits on) to the subframe - my factory tow loop thingy was bolted there.......
it was easier for me than using the above mentioned standard mounting holes
Old Feb 3, 2008 | 02:56 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
I did mine like this...
Old Feb 4, 2008 | 10:23 AM
xbcrguy182x's Avatar
Nice nice...im thinking about getting that too. If you can, record the exhaust sound. We would like to hear it. :-)
Old Feb 4, 2008 | 02:07 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Pacesetter headers, !cat, and the dynomax cat-back, stock motor
http://www.fquick.com/videos/2_8_idle/1901
That was my old setup. Since then I have gotten a Magnaflow and a cat back on.
Old Feb 4, 2008 | 03:27 PM
grimmcs's Avatar
Car: 91 Camaro
Just as a comparison...here is my Dynomax with stock exhaust manifolds...
http://s166.photobucket.com/albums/u...t=da6861b2.flv
Old Feb 5, 2008 | 06:54 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Sound clip of mine is on here somewhere.
My dynomax on the v6 car I had bolted up fine in the rear. They did put the flange to the cat on backwards. that sucked ***
Old Feb 6, 2008 | 01:03 PM
PitBullPonyCar1's Avatar
Car: 1986 Camaro
Engine: 2.8L V6
Transmission: 5 speed
Quick question for 2.8 how much power did you gain with that setup cuz im thinking about the same for mine and wasnt sure if it was worth it or to go with an exhaust for a 350 like the flowmaster 80's series
Old Feb 6, 2008 | 07:59 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Anything is better than stock exhaust.
Old Feb 6, 2008 | 08:28 PM
ohiotemplar's Avatar
Car: 1992 Camaro RS V6
Engine: 3.1 V6 MFI
Axle/Gears: 3.23 stock
Did you get that from jegs? If so, did it come with a cat?
Old Feb 7, 2008 | 03:08 AM
Kryppy's Avatar
Car: 87 Camaro
Got Dynomax Turbo Exhaust system from Summit (I don't think Jegs sells them). Did not come with cat. I don't like/believe in cats anyway. First thing I do when I get a car is throw the cat. away or sell it. From my experience it just chokes the exhaust system too much. I know, I know I am destroying the ozone- I apologize.
Old Feb 7, 2008 | 06:03 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
They make highflow cats...
Hotrodboba400
Dec 10, 2019 07:07 PM
Dyno Don
Jan 24, 2016 08:24 AM
New2Chevy
Sep 28, 2015 12:35 AM
Stryker412
Sep 7, 2015 09:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
