HT 3.4L Crate engine
Car: 85 camaro
Engine: 2.8L v6
Hey guys....i am new to this site, and just bought my first Camaro. I picked up an 85 2.8mpfi v6. I got it for $350 under the pretense that it only needed a fuel pump. (Of course i knew this was a gamble, but the body and interior are almost perfect.....no rips or tears inside, no dents or dings outside....could use a coat of new paint tho). Every thing on this car is original as far as i can tell, and i couldn't let such a beautiful, well kept car go to the crusher. I brought her home and immediately put her up on ramps, dropped the tank and put in a new fuel pump. HUGE pain in the neck.....but that fact is well documented. To my surprise she started right up, no problem idling even after a bottle of fuel system cleaner. Of course i instantly heard a knocking and squealing out of one of the cylinders which my mechanic said probably wouldn't even get back to my house (2blocks lol) with out throwing a rod. After spending DAYS on this site (which was very helpful btw) i decided i should probably go for a 3.4 instead of another 2.8 to get alittle extra performance out of a 6cyl. I have a couple of grand to spend on this car, but it is the only car i have right now so i need to get in running SOON!!!!!!! (i would rather spend a couple of hundred more bucks and get a warrantied engine that i dont have to put together my self and take a month and a half to get it put together correctly.)
Now i have seen swaps on here for hybrids, low/top ends etc.. I'm confident in my ability to do one of these swaps correctly.....but i know it would take me forever to get it right, and time is a big factor to me. (I'm a smart guy, good with my hands, but FAR from a mechanic!!)
I haven't found a complete swap to a 3.4 crate on here.....or for putting a complete fourth gen motor in. I assume there is a reason for this??? It definitely sounds quicker and easier to drop in a brand new motor that is under warranty with zero miles on it that doesn't seem too need too much modification to line up correctly.
So if any of you guys who have done this swap or know anything about it or have any details......or hell even ACTUALLY driven your camaro.....your input on this would be greatly appreciated
http://paceperformance.com/index.asp...D&ProdID=22494
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Re: HT 3.4L Crate engine
The reason you won't find a 3.4L crate motor is that the 3.4 came only in the early 4th gens, which used SFI for the injection method, while ours uses MPFI. The best you can hope for is to buy an engine and swap the intake/fuel/pulleys over to the crate motor.
Car: 85 camaro
Engine: 2.8L v6
so...there is NO WAY to change my mpfi set up to spi?? (different ecm or a custom chip or anything??) the product website states it is possible simply by keeping the 2.8 timing cover, and getting a custom chip. (and no i don't believe everything i read on the internet!!) If that is NOT the case then i will drop in another 2.8 and then rebuild to a 3.4 when i get the time.......but i sure would love to find a way to drop a 3.4 in without having to do this project twice....like i said this is my only car so i need it RUNNING...... even if i do have to keep the little ol' 2.8
The 3.4 will bolt in just the same as a 2.8. Get a longblock and use your manifolds, distributor (in place of the oil pump drive), and timing set/covers are the same between the two engines.
Your ECM and injectors will work fine, but may want to bump up the fuel pressure a little to compensate for the larger displacement. This can be done by using a Holley AFPR for the TPI's, bolts right in.
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
You don't need to change the fuel pressure. Won't hurt, but not neccecary. As soon as it gets into closed loop the ecm will correct the afr. You'll probably be making close to 160hp with the 3.4 block which is safe with the stock injectors.
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
http://www.sdparts.com/product/12363...eAssembly.aspx
Do this! It is a direct bolt in. Just drop it in and go. You can fine tune injector size and fuel pressure later, but it will just go right in...
Car: 85 camaro
Engine: 2.8L v6
Hey thanks for the price look-out Kris!! i found the one on that sight......it just didn't have as much information at the bottom of the page for camaros instead of the s-10's, so i thought it might be more helpfull for information to anyone helping me out here!!!
Look for the username Coolrimsatleast, he did a 2.8-3.4 swap and made several threads about it (including the fueling issues).
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
My swap went well didn't change anything but the top end. They guy I got it from gave me everything from top to bottom. The only issue I have is when the car is cold it runs rich till it warms up and then it mellows out. The way I can tell is you can smell it and then it goes away after 5 mins. So it is a wise choice you can really tell the difference in power.
Wish you the best and have fun!
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I have done a full 3.4 SFI swap. Not worth it since these cars came with MPFI. Time is not on your side, do not even think about the SFI wire swap then.
If you get a crate motor, follow the directions I typed up on here starting at where the motor is stripped bare.
You will need to get some 17lb injectors. You could atleast start it on your 2.8 injectors, but it will run lean. I belive I have 2 sets of 17lb, and a set of 19lb injectors I need to get rid of(hint hint).
https://www.thirdgen.org/forums/v6/3...highlight=swap
edit3rd time. Also, your 2.8 is externally balanced. You will have to get a flywheel or flexplate from a 3.1 or 3.4 if that crate motor doesnt come with one. I may have a flexplate as well. (I keep finding spare parts from when I had a v6)
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Engine: 350 S-TPI
Ive asked for that thread to be a sticky. As you see it hasnt.
If everyone would keep posting the 3.4 questions in it, it would either stay up top, or be made sticky.
Car: 89 V6 Camaro
Engine: 2.8
I'll keep that thread in mind when I start assmebling the motor. All I have is the block, I still need the internals.
Transmission: 5-speed/T-5
It seems that the mods for the forum are either lacking or slacking. There's a lot that should be moderated (cleaned up, locked, stickied unstickied (sic), etc).
At one time I was asked by a previous mod if I was interested, but nothing ever came of it.
Engine: 350 S-TPI
I was asked at one time as well. However I couldnt due to some shinanagans(sp?) going on at the time.
theshackle
Mar 5, 2017 06:37 PM
