Burnt Valve??
Old Feb 14, 2008 | 05:10 PM
pierced1's Avatar
Car: 1990 RS
Engine: 3.1 V-6
Transmission: Auto-?
Axle/Gears: I dunno yet...
Burnt Valve??
Is there a way i can tell for sure that i have a burnt valve?
The reason i ask is because i broke one of the bolts that holds the catalytic converter to the front of the exhaust. I drove it like that for about 2 weeks, because the bolt was broke off in the threaded bolt hole, and i didn't really have a way to fix it. Anyways, its fixed now, but it misses really bad when you go down the road. I've always heard if you drive one with an exhaust leak like that that you will burn up a valve. Figures that since i knew that that i wouldn't drive my car with the leak, but didn't have much of an option. Any help would be greatly appreciated. This is on a 90 rs camaro with 3.1 v6.
Old Feb 15, 2008 | 12:01 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Burnt Valve??
I don't think that exhaust leak is close enough to the engine to bend a valve. You most likely have a different issue. You can do a cylinder leak down test to check for valve problems.
I'd start with basic troubleshooting and tune up stuff.
Old Feb 15, 2008 | 07:49 AM
pierced1's Avatar
Car: 1990 RS
Engine: 3.1 V-6
Re: Burnt Valve??
Thanks for the information. It just started after the exhaust leak is why i was thinking that it would be the cause of it. I just recently done a basic tune up. wires,plugs,dis cap, new vac hoses, etc. I will check back and make sure i didn't forget something.
Old Feb 15, 2008 | 01:27 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Re: Burnt Valve??
Pull the plugs and check them and look at your O2 sensor.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
Formula8r89
Sep 22, 2015 04:24 PM
gta892000
Sep 16, 2015 12:37 AM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
