oil pressure switch
Old Feb 17, 2008 | 10:59 PM
831chevyman's Avatar
Car: 67 Camaro/91 Camaro
Engine: 350/3.1 v6
Transmission: M22/stock
Axle/Gears: 3.73 GM 12 Bolt/stock
oil pressure switch
would you guys be able to let me know where the oil pressure switch is on a 91 3.1 v6...
Old Feb 17, 2008 | 11:33 PM
thirdgenfcarnut's Avatar
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 4L60
Axle/Gears: stock 3.23
Re: oil pressure switch
Right above where the oil filter goes. You will see a wire harness going straight to it. Easiest to see when looking down at the motor from the drivers side.
Old Feb 18, 2008 | 12:27 AM
Engine: 350/3.1 v6
alright i had seen it there but wasnt sure if it was that one... and is there only one or is there another one?
Old Feb 18, 2008 | 06:19 AM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Thats the only one.
Old Feb 18, 2008 | 03:18 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
There's 2 on some. One's for the guage and one's a switch to kill the fuel if there's no pressure.
Old Feb 18, 2008 | 10:27 PM
Engine: 350/3.1 v6
would you know where they are on the engine cause i replaced one and the pressures fine now but now that i turn off the car the fuel pump stays on and i can turn it off by unplugging the switch
Old Feb 19, 2008 | 06:38 AM
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 4L60
Put the old one back in. If the fuel pump goes back to working the way it is supposed to then you were either given the wrong sending switch or its defective.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
TA8487
Aug 16, 2015 12:21 PM
