split decision
Old Feb 18, 2008 | 11:06 AM
mprosco91's Avatar
Car: Camaro RS
Engine: 2.8L
Transmission: 5 speed
split decision
I have an 89 2.8. I'm lookin' to be different. I figured, gettin' the GMMG exhaust or the TSP Rumbler would be the best way to do that. Just wondering what modifications I would have to do for either one? I'm gettin' the pacesetter headers and y-pipe soon. Should I get the ceramic coated or painted? The Pacesetters dont work with the smog pump. I want to remove it. Does anyone know if the smog delete pully will fit the 2.8 or is it just for the V8s or should I just run my belt a different way? Also, after the pacesetters, what should I do about a highflow cat (in/out) and then from there back into the GMMG or TSP? I'm not lookin' to sound like a V8 or anything, cause I know I wont. Just wanna be different. And someone told me to cut the dynomax bullet out of the TSP and put a classic chambered muffler in there instead. Why would I do that? That is if I went with the TSP. I hoping you guys can help me out. I really like the GMMG, but quite expensive. If you guys lean more torwards the GMMG and have one for sale for cheap or know where I can get one for cheap, definitely let me know. Thanks guys.
Old Feb 18, 2008 | 02:20 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: split decision
Get the coated headers unless your cheap like me and get the painted. Coated will last longer and look better longer. Just get a 2.5" Magnaflow cat off ebay. I didn't know that the 2.8s had a smog pump. To my knowledge mine didn't but has a pulley where it should be but the parts store sells belts that are short enough to bypass it. The TSP exhaust is really loud and raspy, I would go GMMG just to see how it sounds.
There is a vid floating around here of a guy who has one of those chambered mufflers and a resonator of some sort, sounds pretty good.
Old Feb 18, 2008 | 08:43 PM
mprosco91's Avatar
Car: Camaro RS
Engine: 2.8L
Re: split decision
The end of the pacesetter y-pipe is 2.25". So should I get a 2.25" inlet with a 2.5" outlet or 2.5" all the way through? Also, the i-pipe for both systems are 3". How would I go about connecting them to the 2.5" cat? Also, do you know where I can get the GMMG system for cheap? It's quite expensive directly from GMMG. I love their slash tips though. Please get back to me ASAP. I appreciate your help so far.
Old Feb 18, 2008 | 08:54 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Re: split decision
Just get a 2.5" pipe made. Any exhaust shop should be able to do it. 3" is too big for our motors. I'm not sure if they make a 2.25" in/2.5" out high flow cat. If not then any shop can easily adapt a 2.5" in/out cat to the exhaust. I don't know where you can get the GMMG exhaust for cheap, just keep your eyes open for a used system. The GMMG exhaust is just pretty much the muffler and tail pipes and the TSP rumbler is pretty much just a bullet/glasspack type muffler that you could jsut buy anywhere. If you want to go chambered like the GMMG exhaust then look up stainless works exhaust and classic chambered exhaust. They make longer chambered type mufflers that can take the place of part of the I-pipe.
Used GMMG:
http://cgi.ebay.com/ebaymotors/82-02...spagenameZWDVW
Old Feb 18, 2008 | 09:07 PM
mprosco91's Avatar
Car: Camaro RS
Engine: 2.8L
Re: split decision
Used GMMG:
Thanks so much. Quick question. Since the used system doesnt have an i-pipe I could have a 2.5" made all the way back til it gets to the mufflers and just have then expand the pipe at the end. Sound good?
Old Feb 18, 2008 | 09:09 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Re: split decision
A muffler shop with a good exhaust guy can make you anything for exhaust.
Old Feb 18, 2008 | 10:08 PM
mprosco91's Avatar
Car: Camaro RS
Engine: 2.8L
Re: split decision
Nice. Think that's what I'll do. I'll definitely post a clip of how it sounds with everything too when it's all done. Also, I know your car didnt come with the smog pump, but do you know if the delete pulley will fit? I'd like to keep the stock belt size. Thanks so much for your help. I really appreciate it.
Old Feb 18, 2008 | 10:17 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: split decision
Just going to throw my opinion in here...I would go with headers//high flow cat//dynomax cat-back. I havent heard one of these v6s that actually sounded semi-decent with a glasspack or bullet style muffler. Now on v8s...you can run straight headers and it would sound awsome.
Its your car though...do what you want to do. Im just thowing my opinion into the mix.
Old Feb 19, 2008 | 01:23 AM
mprosco91's Avatar
Car: Camaro RS
Engine: 2.8L
Re: split decision
All opinions are appreciated. I've seen a lot of people with the dynomax catback. I'm just trying to be different. If everything ends up sounding like ****, I'll prolly go with what everyone else is doing. Just trying to be different. Who I am.
Old Feb 19, 2008 | 07:04 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Re: split decision
Understandable, just don't go SLP loudmouth. Sounds horrible. When you take off your smog pump and go get another belt the shop will ask you if you have a smog pump or not, since you won't then they will give you a belt short enough.
Old Feb 19, 2008 | 03:24 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: split decision
im running glass pack - not choice car came with it, its very 'raspy' i quite like it. suits the higher revs more. sounds cacky low down.
Old Feb 19, 2008 | 04:10 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Re: split decision
Its all a matter of preference. It may be because we're mostly American and prefer the low V8 rumble to higher pitched and raspyness.
Old Feb 20, 2008 | 09:26 AM
mprosco91's Avatar
Car: Camaro RS
Engine: 2.8L
Re: split decision
Thanks so much for all your help. I'll let you know how everything sounds when it's done. Hopefully by the end of march, early April it'll all be done. I ordered a new headliner, sunvisors, and sail panels. so I'll prolly be puttin all those in first. But thank you again.
Old Feb 20, 2008 | 12:57 PM
grimmcs's Avatar
Car: 91 Camaro
Re: split decision
Yea make sure you put up a sound clip when youre done. Ive never heard a GMMG on a v6...I want to hear what it sounds like.
Old Feb 20, 2008 | 01:04 PM
mprosco91's Avatar
Car: Camaro RS
Engine: 2.8L
Re: split decision
Yeah I've never heard one or seen someone put one on a v6. I'm hopin' I win the auction and everything sounds good. I cant wait.
Old Feb 24, 2008 | 10:57 PM
mprosco91's Avatar
Car: Camaro RS
Engine: 2.8L
Re: split decision
Got bad news everyone. Turns out I wont be gettin any new exhaust right now. Let alone the gmmg. Got some financial issues to work out first. Definitely sucks. I was so excited on gettin everything and being to first to do something different. (as far as I know) Hopefully I'll still be the first to do it, but I'm sure someone will beat me to it now. Lol. Oh well.
ZZ3Astro
Aug 13, 2019 12:57 AM
MrPackstin
Oct 25, 2017 08:09 PM
1992Z28!
Nov 19, 2015 07:33 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
