V6 distributor motor to DIS
Old Feb 19, 2008 | 10:06 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Here's a link for anyone looking to do a DIS swap. Easy swap, really. https://www.thirdgen.org/forums/dfi-...=1#post3646515
Old Feb 23, 2008 | 07:17 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: V6 distributor motor to DIS
I did this with Buick V6 engines as well. The pictures look exactly like the wiring diagrams from my GM Fuel Injection manual from 1996. Interesting...
Old Feb 23, 2008 | 07:35 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
What's the benefit of DIS over distributor?
Old Feb 23, 2008 | 09:54 PM
firstfirebird's Avatar
3x00 heads
Just so everyone knows, a 3.1 with 3400 heads is only 11.14:1 compression. Just need a crank postion sensor now, hint hint.
Old Feb 23, 2008 | 11:11 PM
bl85c's Avatar
Car: '85 maro
Also more accurate timing, never having to set base timing again and less stuff to spend money on (cap, rotor, dizzy, ect.)
Old Feb 24, 2008 | 12:23 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
There's a major component missing from that, and is the largest reason people have not swapped to DIS from dizzy, and that is the crank trigger. If you have a 3.4, this is not a problem, but a 2.8 or 3.1 does not have the provisions for this.
Also it's a 7x reluctor ring, not a "3x" as mentioned in that thread. There are 6 equally spaced notches and one home signal 50* before #4 TDC IIRC, but I'll have to check the location of that home signal again.
If you go back to some of my old posts (probably from my old account as "The_Raven"), you'll see that I had said that this simple modification in wiring should have worked. I would have tested it long ago, if my truck was already EFI when it was built, but since I had toi convert it anyway, I just used the FWD ECM and MEMCAL from the start.
Old Feb 24, 2008 | 07:07 AM
I've seen it called both. In literature as well as forums.
Doesn't the ICM fire the pair each time? ie the home notch would be just before #1 and #4 simultaineously?
Also if you used the FWD ECM, did you need to use a 3.4 or FWD crank pulley for that sensor?
Old Feb 24, 2008 | 10:53 AM
In any official or highly technical (as in FSM or similar) manuals, that I've looked at, it's refered to as a 7x.
Like I said it's been a while, but I think we figured out it was in refernce to #4 for some reason, though that should equate to being for #1 as well.
I used the 2.8 harmonic balancer and crank pulley. My grandfather and I made a crank trigger that mounts like an MSD crank trigger.
If you are thinking that the 24x pulley mounted reluctor ring is needed, it's not, at least not for the OBD1 FWD ECM and set-up. The OBD1 FWD ECM or EFI system rather only needs the single 7x crank trigger for the ignition.
Old Feb 24, 2008 | 03:39 PM
That confirms my suspicion that it's for SFI, like the extra cam lobe.
Old Feb 24, 2008 | 04:39 PM
Yes, it is. The 24x sensor is supposed to shorten the crank time. :roll:
The cam positions sensor is strictly for the SFI. Without triggers from this sensor the SFI PCM reverts to btach fire and posts a CEL.
1992 Trans Am
May 10, 2023 07:19 PM
xxx3man`
Sep 23, 2015 10:37 PM
1992Vortec
Aug 31, 2015 08:05 PM
355sbcTPI
Aug 19, 2015 04:38 PM
cstrobel65
Aug 15, 2015 10:19 AM
