Can someone decipher this info?
Old Feb 22, 2008 | 04:54 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
I let the car set a little before I used Tunerpro to get the info listed here. The car was in Park and idling. I wrote down the values Tunerpro was showing me as the car ran....
TPS .045V
Coolant Temp. 67.25C
Battery Volt 14.10
Volt at Fuel Pump 13.70
RPM 875 (Gauge shows 1500)
Engine Air flow 19 Grams/Sec
Baro. Pressure 4.67
Target AFR 14.70
O2 Sensor 492.84
O2 Cross Counts Jumps from 45 - 170
Integrator 128
Block Learn 118
Injector Final Pulse Width 2.18
IDLE/IAC
RPM 800
IAC Motor 47 Steps
Spark Adv, Relevant to TDC 23.91 degrees
Spark Advance 14.06 degrees
Knock Retard 0.00
MAP Sensor 1.43 Volts
ALDL Flags
TCC Locked
In 2ND Gear TRUE
O2 RICH/LEAN RICH
I at least my Tach is WAY off and needs adjusting. I'm also concerned about the TCC info and it saying the car is in 2nd gear whrn its in Park. The Rich part speaks for itself.
Ken
Old Feb 23, 2008 | 09:44 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Can someone decipher this info?
For the TCC & 2nd gear there may be some errors in the .ads file. Also, ther eis only a hi-hear switch in the trans, nothing for 1, 2, & 3.
Everything else looks typical.
RBob.
Fanatic1074
Oct 3, 2022 05:57 AM
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
