oil pressure switch
Old Mar 2, 2008 | 07:48 PM
89camaroRS6's Avatar
oil pressure switch
i removed ny oil pressure switch to put on my headers and the threads are stripped and it wont go back in the aftermarket ones are all too small and will not fit in the hole do you guys think the block is stripped also or is there an easy solution to the problem
Old Mar 2, 2008 | 08:09 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Re: oil pressure switch
The oil pressure switch goes into the oil filter housing,which is bolted to the block. You could simply replace the housing.
Old Mar 3, 2008 | 11:27 AM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
in general the after-market sensors are smaller so the fit the largest number of application with the use of an adapter. at least thats what all of the ones i have bought.
take the sensor down to your parts store and get an adapter that fits.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
TA8487
Aug 16, 2015 12:21 PM
